Etwas OT - Panasonic analog Tel. resetten? (Elektronik)
verfasst von tweety, 29.12.2020, 16:58 Uhr
» kann mir da jemand weiterhelfen?
» habe so ziemlich alles im Net abgesucht,finde aber leider nichts um mein
» Telefon Panasonic KX-TG6822 zu resetten.
KX-TG6822.... hat das noch einen suffix?
Vlt. hilft das:
https://servlib.com/panasonic/telephone/kx-tg6811cab-kx-tg6811cam-kx-tg6812cab-kx-tg6821cab-kx-tg6821cam-kx-tg6822cab-kx-tga681rub-kx-tga681rum.html?start=25
via https://www.etools.ch/searchSubmit.do?query=%2Bkx-tg6822+%2Bservice-manual&country=web&language=all
26
KX-TG6811CAB/KX-TG6811CAM/KX-TG6812CAB/KX-TG6821CAB/KX-TG6821CAM/KX-TG6822CAB/KX-TGA681RUB/KX-TGA681RUM
8.3.
How to Clear User Setting
Units are reset to the Factory settings by this operation (Erase recorded Voice messages, stored Phone numbers, Caller list and
etc.)
Note:
• Some menus are not reset. Refer to Operating Instructions (P.20).
• The reset menus differ depending on the following operations.
• This operation should not be performed for a usual repair.
8.3.1.
Resetting both base unit and handset
1 Connect the AC adaptor to the base unit and install the charged batteries into the handset.
2 Confirm the handset is registered to the base unit
If the handset is not registered to the base unit , register it.
3 Lift the handset and press {ih} to put the handset in standby mode
4 Press 1 5 9 and * key of the handset simultaneously until a confirmation tone is heard
5 Disconnect the AC adaptor, then remove the battery.
8.3.2. Resetting only handset
1 Install the charged batteries into the handset.
2 Lift the handset and press {ih} to put the handset in standby mode.
3 Press 3 5 7 and # key of the handset simultaneously until a confirmation tone is heard.
4 Remove the battery
» Bei einigen Panasonic Analogtelefonen gibt man unter Menue - Einstellungen
» ein: #136 und auf ok.Das muß dann noch mit ja bestätigt werden.
» Bei diesem Tel. funktioniert das aber nicht.Auch nicht nach vorherigem
» Abmelden von der Basisstation.
» Hatte die Basis schon 2 Stunden vom Netz und am Mobilteil die Akkus
» raus,bleibt alles gespeichert.
» Am Mobilteil sieht man bei geöffnetem Batteriefach 4 Lötpunkte,ebenso
» rückseitig an der Basis.Hab die Kontakte mal spannungsfrei überbrückt,half
» aber auch nicht.
» Vielen Dank im Voraus.
Etwas OT - Panasonic analog Tel. resetten? - Hörbi(R), 29.12.2020, 14:27 (Elektronik)
Etwas OT - Panasonic analog Tel. resetten? - DIY-Basler(R), 29.12.2020, 14:51
Etwas OT - Panasonic analog Tel. resetten? - Hörbi(R), 29.12.2020, 15:34
Etwas OT - Panasonic analog Tel. resetten? - DIY-Basler(R), 29.12.2020, 15:53
Etwas OT - Panasonic analog Tel. resetten? - Hörbi(R), 29.12.2020, 16:02
Etwas OT - Panasonic analog Tel. resetten? - DIY-Basler(R), 29.12.2020, 16:22
Etwas OT - Panasonic analog Tel. resetten? - tweety, 29.12.2020, 16:58
Etwas OT - Panasonic analog Tel. resetten? - simi7(R), 30.12.2020, 18:22
Etwas OT - Panasonic analog Tel. resetten? - tweety, 04.01.2021, 21:27
Etwas OT - Panasonic analog Tel. resetten? - DIY-Basler(R), 04.01.2021, 22:36
