Raspberry Pi als WLan Router einrichten (Netzwerktechnik)
Hallo Bastelix,
sorry hat etwas gedauert bis ich hier weitermachen konnte.
die Fehlermeldung lautet bei:
sudo systemctl start hostapd:
Failed to start hostapd.service: Unit hostapd.service is masked.
und bei
sudo systemctl enable hostapd:
Synchronizing state of hostapd.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable hostapd
Failed to enable unit: Unit file /etc/systemd/system/hostapd.service is masked.
Das journalctl -xe gibt aus:
-- The start-up result is done.
Mär 12 10:03:51 raspberrypi systemd[1]: apt-daily.timer: Adding 6h 24min 1.86870
Mär 12 10:03:51 raspberrypi systemd[1]: apt-daily.timer: Adding 6h 21min 16.3855
Mär 12 10:03:51 raspberrypi systemd[1]: Starting Daily apt upgrade and clean act
-- Subject: Unit apt-daily-upgrade.service has begun start-up
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- Unit apt-daily-upgrade.service has begun starting up.
Mär 12 10:03:52 raspberrypi systemd[1]: Started Daily apt upgrade and clean acti
-- Subject: Unit apt-daily-upgrade.service has finished start-up
-- Unit apt-daily-upgrade.service has finished starting up.
Mär 12 10:03:52 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 43min 44
Mär 12 10:03:52 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 24min 7.
Mär 12 10:12:41 raspberrypi sudo[1379]: pi : TTY=pts/0 ; PWD=/home/pi ; US
Mär 12 10:12:41 raspberrypi sudo[1379]: pam_unix(sudo:session): session opened f
Mär 12 10:12:41 raspberrypi sudo[1379]: pam_unix(sudo:session): session closed f
lines 1671-1693/1693 (END)
Mär 12 10:03:51 raspberrypi systemd[1]: apt-daily.timer: Adding 6h 24min 1.868706s random time.
Mär 12 10:03:51 raspberrypi systemd[1]: apt-daily.timer: Adding 6h 21min 16.385529s random time.
Mär 12 10:03:51 raspberrypi systemd[1]: Starting Daily apt upgrade and clean activities...
Mär 12 10:03:52 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Mär 12 10:03:52 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 43min 44.962407s random time.
Mär 12 10:03:52 raspberrypi systemd[1]: apt-daily-upgrade.timer: Adding 24min 7.665524s random time.
Mär 12 10:12:41 raspberrypi sudo[1379]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/systemctl
Mär 12 10:12:41 raspberrypi sudo[1379]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mär 12 10:12:41 raspberrypi sudo[1379]: pam_unix(sudo:session): session closed for user root
ls -l /etc/hostapd/hostapd.conf:
-rw------- 1 root root 305 Mär 7 20:03 /etc/hostapd/hostapd.conf
cat /etc/default/hostapd:
# Defaults for hostapd initscript
# See /usr/share/doc/hostapd/README.Debian for information about alternative
# methods of managing hostapd.
# Uncomment and set DAEMON_CONF to the absolute path of a hostapd configuration
# file and hostapd will be started during system boot. An example configuration
# file can be found at /usr/share/doc/hostapd/examples/hostapd.conf.gz
#DAEMON_CONF=""
# Additional daemon options to be appended to hostapd command:-
# -d show more debug messages (-dd for even more)
# -K include key data in debug messages
# -t include timestamps in some debug messages
# Note that -B (daemon mode) and -P (pidfile) options are automatically
# configured by the init.d script and must not be added to DAEMON_OPTS.
#DAEMON_OPTS=""
RUN_DAEMON=yes
DAEMON_CONF="/etc/hostapd/hostapd.conf"
Ich verwende die Aktuelle Version von Raspbian
cat /proc/version gibt aus:
Linux version 4.14.98-v7+ (dom@dom-XPS-13-9370) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1200 SMP Tue Feb 12 20:27:48 GMT 2019
Vielen Dank für Deine Hilfe!
Mäercle
