vor 116 Jahren fing es an.... (Netzwerktechnik)
verfasst von Hartwig(R), 24.01.2017, 20:09 Uhr
in Englisch, aber da ist zu lesen:
"On 15th of March, 1901 the patent office in Berlin granted the patent No. 118717 to the
French inventor C. Loubery [Loub_01]. It was the first notable description of a remotely con-
trolled load management system. This is why the IEEE standardization group P1901
[IEEE_09] selected this number for their name. Loubery used a multiple carrier signal, with
one frequency carrier to control one target device. The client implemented a dedicated fixed
filter to detect ‘his’ frequency. The bit rate was not very high, but it was clearly a powerline
communication. "
und etwas weiter:
"The Carrier Frequency Transmission of voice over high voltage transmission networks be-
gan in the 1920’s. The network provided a bidirectional communication channel which was
important for management and monitoring purposes, because at the beginning of electrifica-
tion, just a telephone network could not cover the communication between transformer stations
and power plants. Due to favorable transmission characteristics, low noise and relatively high
carrier frequencies (15-500 kHz), distances of up to 900 km were reached with a transmission
power of 10 W. Initially, only voice was transmitted and amplitude modulation was used.
Later, telemetering and controlling functions were also implemented."
Quelle: http://www.ets.uni-duisburg-essen.de/download/public/Schwager_Andreas_Diss.pdf
interessant, 900km Reichweite mit 10W über Hochspannungsleitungen....(heute wohl nicht mehr)
Grüsse
Steh auf dem Schlauch bei PLC - Berti, 24.01.2017, 12:16 (Netzwerktechnik)
Steh auf dem Schlauch bei PLC - xy(R), 24.01.2017, 12:39
Steh auf dem Schlauch bei PLC - simi7(R), 24.01.2017, 13:25
Steh auf dem Schlauch bei PLC - Berti, 24.01.2017, 14:07
Steh auf dem Schlauch bei PLC - Berti, 24.01.2017, 14:34
Steh auf dem Schlauch bei PLC - xy(R), 24.01.2017, 14:39
Steh auf dem Schlauch bei PLC - Berti, 24.01.2017, 14:40
Steh auf dem Schlauch bei PLC - Berti, 24.01.2017, 14:41
Steh auf dem Schlauch bei PLC - Gast, 24.01.2017, 14:47
Steh auf dem Schlauch bei PLC - Berti, 24.01.2017, 14:49
Steh auf dem Schlauch bei PLC - Berti, 24.01.2017, 14:48
Steh auf dem Schlauch bei PLC - Berti, 24.01.2017, 15:09
Steh auf dem Schlauch bei PLC - Elektron, 24.01.2017, 15:15
Steh auf dem Schlauch bei PLC - Berti, 24.01.2017, 15:19
Steh auf dem Schlauch bei PLC - Elektron, 24.01.2017, 18:08
Steh auf dem Schlauch bei PLC - Berti, 24.01.2017, 18:28
Steh auf dem Schlauch bei PLC - der wieder, 24.01.2017, 15:31
Problem mit überlagerten Ladungsträgerschwingungen - Berti, 24.01.2017, 17:58
Das ist nicht supper... - Gast, 24.01.2017, 18:34
Das ist nicht supper... - Berti, 24.01.2017, 18:42
Das Babyphone und anderes lässt grüssen... - schaerer(R), 24.01.2017, 18:53
Das Babyphone und anderes lässt grüssen... - Berti, 24.01.2017, 19:16
Quanten - Phänomenologie...... - schaerer(R), 24.01.2017, 19:47
Quanten - Phänomenologie...... - matzi682015(R), 29.01.2017, 15:16
vor 116 Jahren fing es an.... - Hartwig(R), 24.01.2017, 20:09
vor 116 Jahren fing es an.... - schaerer(R), 24.01.2017, 20:28
vor 116 Jahren fing es an.... - Berti, 24.01.2017, 20:36
vor 116 Jahren fing es an.... - Hartwig(R), 24.01.2017, 21:19
Das Babyphone und anderes lässt grüssen... - bigdie(R), 24.01.2017, 22:02
Das Babyphone und anderes lässt grüssen... - Berti, 25.01.2017, 11:24
Das Babyphone und anderes lässt grüssen... - Hartwig(R), 25.01.2017, 12:21
Das Babyphone und anderes lässt grüssen... - Berti, 25.01.2017, 13:42
Das Babyphone und anderes lässt grüssen... - Hartwig(R), 25.01.2017, 15:00
Einführung in die Kanalkapazität - Berti, 26.01.2017, 11:20
Einführung in die Kanalkapazität - Hartwig(R), 26.01.2017, 11:52
Einführung in die Kanalkapazität - Berti, 26.01.2017, 12:07
