Leistungsverteilung in Lautsprecherbox (Elektronik)
verfasst von xy
, 29.11.2016, 19:34 Uhr
» » » Na dann:
» » » P=R*I²
» » Oder einfach die Alt-Taste drücken und den Widerstand anklicken.
» Das funktioniert bei DC op pnt
» ...aber leider nicht bei AC-Analysis
Syntax: Vxxx n+ n- wavefile= [chan=]
This allows a .wav file to be used as an input to LTspice. is either a full, absolute path for the .wav file or a relative path computed from the directory containing the simulation schematic or netlist. Double quotes may be used to specify a path containing spaces. The .wav file may contain up to 65536 channels, numbered 0 to 65535. Chan may be set to specify which channel is used. By default, the first channel, number 0, is used. The .wav file is interpreted as having a full scale range from -1V to 1V.
http://www.audiocheck.net/testtones_pinknoise.php
