Wie neg. Eing.-U oder Ausg.-U abblocken ? (Elektronik)
» » » Warum Holzweg?
» » Weil du eigentlich nur einen Widerstand brauchst. Und ganz ängstliche
» » nehmen noch eine zusätzliche Schottkydiode.
» Wofür benötige ich nur EINEN Widerstand ?
Um dein Problem mit der negativen Spannung am Shunt zu beseitigen.
Aus dem Datenblatt von TI:
"Note 3: This input current will only exist when the voltage at any of the input leads is driven negative. It is due to the collector-base junction of the input PNP
transistors becoming forward biased and thereby acting as input diode clamps. In addition to this diode action, there is also lateral NPN parasitic transistor action
on the IC chip. This transistor action can cause the output voltages of the op amps to go to the V+voltage level (or to ground for a large overdrive) for the time duration
that an input is driven negative. This is not destructive and normal output states will re-establish when the input voltage, which was negative, again returns to a value
greater than −0.3V (at 25°C)."
