WLAN-Radio Adressen (Elektronik)
Da ist beim kopieren was schief gelaufen, hier nochmal:
#include
#define UNDEFINED -1
#ifdef ARDUINO_ARCH_ESP8266
#include
#define VS1053_CS D1
#define VS1053_DCS D0
#define VS1053_DREQ D3
#endif
#ifdef ARDUINO_ARCH_ESP32
#include
#define VS1053_CS 5
#define VS1053_DCS 16
#define VS1053_DREQ 4
#endif
// Lautstärke:
#define VOLUME 80 // maximal 99
VS1053 player(VS1053_CS, VS1053_DCS, VS1053_DREQ, UNDEFINED, SPI);
WiFiClient client;
// WiFi hier eintragen:
const char *ssid = "euer SSID Name";
const char *password = "SSID Passwort";
//Erfolgreich getestete Sender:
const char *host = "ic.radiomonster.fm";
const char *path = "/tophits.ultra"; //Tophits Kanal
//const char *path = "/dance.ultra"; //Dance Kanal
//const char *path = "/evergreens.ultra"; //Evergreens Kanal
//const char *path = "/schlager.ultra"; //Schlager Kanal
int httpPort = 80;
//const char *host = "icecast.omroep.nl";
//const char *path = "/radio6-bb-mp3";
//int httpPort = 80;
//const char *host = "puma.streemlion.com";
//const char *path = "/stream";
//int httpPort = 1960;
// Die Puffergröße 64 scheint optimal zu sein. Bei 32 und 128 könnte der Klang blechern klingen
uint8_t mp3buff[64];
void setup() {
Serial.begin(115200);
// 3 Sekunden Pause, bis VS1053 eingeschaltet sind
// sonst startet das System möglicherweise nicht richtig
delay(3000);
// This can be set in the IDE no need for ext library
// system_update_cpu_freq(160);
Serial.println("nnEinfaches Wifi Radio startet");
SPI.begin();
player.beginOutput();
player.setVolume(VOLUME);
Serial.print("Connecting to SSID ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
Serial.print("connecting to ");
Serial.println(host);
if (!client.connect(host, httpPort)) {
Serial.println("Connection failed");
return;
Serial.print("Requesting stream: ");
Serial.println(path);
client.print(String("GET ") + path + " HTTP/1.1rn" +
"Host: " + host + "rn" +
"Connection: closernrn");
void loop() {
if (!client.connected()) {
Serial.println("Reconnecting...");
if (client.connect(host, httpPort)) {
if (client.available() > 0) {
uint8_t bytesread = client.read(mp3buff, 64);
player.playChunk(mp3buff, bytesread);
