LT1764 macht unartige Sachen (Elektronik)
» habe ich nix dran. Wo kann mein Fehler liegen?
Pull up ist vorhanden ?
SHDN (Pin 1/Pin 10): Shutdown. The SHDN pin is used to
put the LT1764 regulators into a low power shutdown
state. The output will be off when the SHDN pin is pulled
low. The SHDN pin can be driven either by 5V logic or
open-collector logic with a pull-up resistor. The pull-up
resistor is required to supply the pull-up current of the
open-collector gate, normally several microamperes, and
the SHDN pin current, typically 7µA. If unused, the SHDN
pin must be connected to VIN. The device will be in the low
power shutdown state if the SHDN pin is not connected.
LT1764 macht unartige Sachen - Sel
, 03.08.2018, 20:42
LT1764 macht unartige Sachen - gast, 04.08.2018, 07:58
LT1764 macht unartige Sachen - Wolfgang Horejsi, 04.08.2018, 10:06
LT1764 macht unartige Sachen - gast, 04.08.2018, 10:21
LT1764 macht unartige Sachen - JBE, 04.08.2018, 12:18
, 04.08.2018, 15:08
LT1764 macht unartige Sachen - JBE, 04.08.2018, 16:05
, 04.08.2018, 17:51
LT1764 macht unartige Sachen - Hartwig
, 04.08.2018, 19:21
, 04.08.2018, 13:01
LT1764 macht unartige Sachen - Wolfgang Horejsi, 04.08.2018, 13:07
, 04.08.2018, 13:21
LT1764 macht unartige Sachen - Wolfgang Horejsi, 04.08.2018, 15:47
