Würfel (Elektronik)
Er geht von 0 bis 6
glaub' mir, ich habe es vor mir aufgebaut.
electronic dice 4026
ist das Stichwort. Dann findest du die Schaltung mehrfach. Die können doch nicht alle spinnen.
Ich suche aber jetzt noch weiter, ob ich irgendwo eine Erklärung finde.
Im Datenblatt steht wohl nichts.
Mit der 0 [NULL] habe ich mich inzwischen angefreundet.
Warum soll man nicht auch Null würfeln können.
edit
schon gefunden:
This count would normally lie between 0 and 6, since at the leading edge of every 7th clock pulse, the counter is reset to zero. This is achieved as follows. Observe the behavior of ‘b’ segment output in the Table. On reset, at count 0 until count 4, the segment ‘b’ output is high. At count 5 it changes to low level and remains so during count 6. However, at start of count 7, the output goes from low to high state. A differentiated sharp high pulse through C-R combination of C4-R5 is applied to reset pin 15 of IC2 to reset the output to ‘0’ for a fraction of a pulse period (which is not visible on the 7-segment display).
Pin 15 is a level-sensitive reset input. As long as it is high, the counter is frozen at 0. Starting at 0, segment B is high but the resistor pulls the right side of C4 to ground. When B goes low for numbers 5 and 6, C4's right side is driven below grond briefly, until it can charge up to ground through R5. Now both sides of C4 are at 0 V. When B goes high for a 7, both sides of Cr jump up. The right side of C4 now is high, and resets the counter to 0 through D1. When reset, the display is at 0 and B still is high, but R5 discharges C4, removing the high signal from the reset input so the counter can count again.
Rudi, der oszilose Lochrasterbastler
