Failed to process makespec for platform 'devices/linux-rasp- (Elektronik)
verfasst von carter88(R), 11.02.2016, 16:31 Uhr
Hallo everybody, I tried to cross compile Qt for pi2 by follow this tutorial http://visualgdb.com/tutorials/raspberry/qt/embedded/
but never succed. now i try this tutorials (https://wiki.qt.io/RaspberryPi2EGLFS)
configuration:
./configure -release -opengl es2 -device linux-rasp-pi2-g++ -device-option CROSS_COMPILE=~/raspi/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf- -sysroot ~/raspi/sysroot -opensource -confirm-license -make libs -prefix /usr/local/qt5pi -extprefix ~/raspi/qt5pi -hostprefix ~/raspi/qt5 -v
i got this error by the configuration
Failed to process makespec for platform 'devices/linux-rasp-pi2-g++'
Project ERROR: Compiler /home/raspberry/raspi/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspian/bin/arm-linux-gnnueabihf-g++ not found. Check the value of CROSS_COMPILE -device-option
Could not read qmake configuration file /home/raspberry/raspi/qtbase/mkspecs/devices/linux-rasp-pi2-g++/qmake.conf.
Error processing project file: /dev/null
Failed to process makespec for platform 'devices/linux-rasp- - carter88(R), 11.02.2016, 16:31
