Dimensioning of resistance for a temperature sensor (Elektronik)
» Die PDF Datei wurde nicht hochgeladen, also noch einmal hier die Aufgabe:
» For the production of a temperature sensor a material needs to be selected.
» Given are the
» dimensions of the metallic wire and target value the final resistances at
» 0°C and at 50°C. The
» following data are showing: p = p(0°C).The material of the resistance is a
» (circular) wire.
» R(0°C) = 100 ohm; R(50°C) = 119 ohm; Diameter D = 16.74 μm; Length l =
» 1 m
» a) Formulate the equation which is necessary to get the unknown
» temperature
» coefficient of this material out of the given data.
» c) Select fitting materials out of the table given below.
Vielleicht ist dieser Link hilfreich:
http://de.wikipedia.org/wiki/Temperaturkoeffizient
Altgeselle
