Dimensioning of resistance for a temperature sensor (Elektronik)
Die PDF Datei wurde nicht hochgeladen, also noch einmal hier die Aufgabe:
For the production of a temperature sensor a material needs to be selected. Given are the
dimensions of the metallic wire and target value the final resistances at 0°C and at 50°C. The
following data are showing: p = p(0°C).The material of the resistance is a (circular) wire.
R(0°C) = 100 ohm; R(50°C) = 119 ohm; Diameter D = 16.74 μm; Length l = 1 m
a) Formulate the equation which is necessary to get the unknown temperature
coefficient of this material out of the given data.
c) Select fitting materials out of the table given below.
Dimensioning of resistance for a temperature sensor - Alex_aaa, 24.01.2013, 15:11
Dimensioning of resistance for a temperature sensor - Alex_aaa, 24.01.2013, 15:13
Vorschlag - Fa. Jumo hat Literatur dazu - geralds
, 24.01.2013, 15:27
Vorschlag - Fa. Jumo hat Literatur dazu - Alex_aaa, 24.01.2013, 15:30
, 24.01.2013, 15:42
Vorschlag - Fa. Jumo hat Literatur dazu - Tim, 24.01.2013, 15:52
, 24.01.2013, 16:37
Vorschlag - Fa. Jumo hat Literatur dazu - Tim, 24.01.2013, 17:01
Vorschlag - Fa. Jumo hat Literatur dazu - schaerer
, 24.01.2013, 21:39
, 25.01.2013, 01:47
, 25.01.2013, 13:29
, 25.01.2013, 13:36
, 25.01.2013, 13:50
, 24.01.2013, 21:30
Dimensioning of resistance for a temperature sensor - Altgeselle
, 24.01.2013, 16:52
Dimensioning of resistance for a temperature sensor - hws
, 24.01.2013, 19:21
Dimensioning of resistance for a temperature sensor - Alex_aaa, 24.01.2013, 19:40
Dimensioning of resistance for a temperature sensor - schaerer
, 24.01.2013, 21:42
Dimensioning of resistance for a temperature sensor - Alex_aaa, 24.01.2013, 23:17
Dimensioning of resistance for a temperature sensor - geralds
, 25.01.2013, 01:46
, 25.01.2013, 13:26
Dimensioning of resistance for a temperature sensor - pph, 25.01.2013, 15:49
Dimensioning of resistance for a temperature sensor - Alex_aaa, 25.01.2013, 15:23
Dimensioning of resistance for a temperature sensor - pph, 25.01.2013, 15:52
, 25.01.2013, 16:20
Dimensioning of resistance for a temperature sensor - Alex_aaa, 25.01.2013, 17:35
