JBE
09.04.2016,
22:13
(editiert von JBE
am 09.04.2016 um 22:15)
eagle3d und povray (Elektronik)
eagle3d funktioniert auch mit der eagle 7 versionen, wen es interessiert
//POVRay-Datei erstellt mit 3d41.ulp v20110101
//C:/Users/xx7-64/Documents/eagle/13,8VSpannungsüberwachung/Spannungsüberwachung.brd
//09.04.2016 22:05
#version 3.5;
//Set to on if the file should be used as .inc
#local use_file_as_inc = off;
#if(use_file_as_inc=off)
//changes the apperance of resistors (1 Blob / 0 real)
#declare global_res_shape = 1;
//randomize color of resistors 1=random 0=same color
#declare global_res_colselect = 0;
//Number of the color for the resistors
//0=Green, 1="normal color" 2=Blue 3=Brown
#declare global_res_col = 1;
//Set to on if you want to render the PCB upside-down
#declare pcb_upsidedown = off;
//Set to x or z to rotate around the corresponding axis (referring to pcb_upsidedown)
#declare pcb_rotdir = x;
//Set the length off short pins over the PCB
#declare pin_length = 2.5;
#declare global_diode_bend_radius = 1;
#declare global_res_bend_radius = 1;
#declare global_solder = on;
#declare global_show_screws = on;
#declare global_show_washers = on;
#declare global_show_nuts = on;
#declare global_use_radiosity = on;
#declare global_ambient_mul = 1;
#declare global_ambient_mul_emit = 0;
//Animation
#declare global_anim = off;
#local global_anim_showcampath = no;
#declare global_fast_mode = off;
#declare col_preset = 2;
#declare pin_short = on;
#declare e3d_environment = on;
#declare environment = on;
#local cam_x = 0;
#local cam_y = 166;
#local cam_z = -81;
#local cam_a = 20;
#local cam_look_x = 0;
#local cam_look_y = -3;
#local cam_look_z = 0;
#local pcb_rotate_x = 0;
#local pcb_rotate_y = 0;
#local pcb_rotate_z = 0;
#local pcb_board = on;
#local pcb_parts = on;
#local pcb_wire_bridges = off;
#if(global_fast_mode=off)
#local pcb_polygons = on;
#local pcb_silkscreen = on;
#local pcb_wires = on;
#local pcb_pads_smds = on;
#else
#local pcb_polygons = off;
#local pcb_silkscreen = off;
#local pcb_wires = off;
#local pcb_pads_smds = off;
#end
#local lgt1_pos_x = 19;
#local lgt1_pos_y = 29;
#local lgt1_pos_z = 18;
#local lgt1_intense = 0.726196;
#local lgt2_pos_x = -19;
#local lgt2_pos_y = 29;
#local lgt2_pos_z = 18;
#local lgt2_intense = 0.726196;
#local lgt3_pos_x = 19;
#local lgt3_pos_y = 29;
#local lgt3_pos_z = -12;
#local lgt3_intense = 0.726196;
#local lgt4_pos_x = -19;
#local lgt4_pos_y = 29;
#local lgt4_pos_z = -12;
#local lgt4_intense = 0.726196;
//Do not change these values
#declare pcb_height = 1.500000;
#declare pcb_cuheight = 0.035000;
#declare pcb_x_size = 52.050000;
#declare pcb_y_size = 35.230000;
#declare pcb_layer1_used = 0;
#declare pcb_layer16_used = 1;
#declare inc_testmode = off;
#declare global_seed=seed(159);
#declare global_pcb_layer_dis = array[16]
0.000000,
0.000000,
0.000000,
0.000000,
0.000000,
0.000000,
0.000000,
0.000000,
0.000000,
0.000000,
0.000000,
0.000000,
0.000000,
0.000000,
0.000000,
1.535000,
#declare global_pcb_real_hole = 2.000000;
nur ein auszug aus der povdatei :-D
geralds(R)
Homepage E-Mail
Wien, AT,
09.04.2016,
22:46
@ JBE
eagle3d und povray
» eagle3d funktioniert auch mit der eagle 7 versionen, wen es interessiert
» .http://www.elektronik-kompendium.de/forum/upload/20160409221306.jpg
» //POVRay-Datei erstellt mit 3d41.ulp v20110101
» //C:/Users/xx7-64/Documents/eagle/13,8VSpannungsüberwachung/Spannungsüberwachung.brd
» //09.04.2016 22:05
» #version 3.5....
Ja, das ist bekannt, bastle auf Bedarf auch damit, falls jemand das von mir wünscht.
Allerdings ist das Schnee von gestern, da niemand mehr damit wirklich arbeitet; proprietär.
Heute ist dies angesagt:
http://www.cadsoft.de/eagle-pcb-design-software/partner-produkte/
Damit bist mit anderen, vor Allem mit Print Herstellern kompatibel.
Ähnlich ist das 3D Spielchen mit Google's-Trimble's Sketchup.
Dieses gefällt mir besser, als povray und ist viel einfacher zu bedienen.
Sketchup wird auch von Konstruktionsfirmen (zB bietet auch RS-Components mit
seinen 3D Ansichten Bauteile im Sketchup Datenformat zum Download an) verwendet.
Ist somit so gesehen auch besser, als mit povray.
http://www.sketchup.com/download
https://eagleup.wordpress.com/
JBE
10.04.2016,
14:58
@ geralds
eagle3d und povray
» » eagle3d funktioniert auch mit der eagle 7 versionen, wen es interessiert
» » .http://www.elektronik-kompendium.de/forum/upload/20160409221306.jpg
» » //POVRay-Datei erstellt mit 3d41.ulp v20110101
» » //09.04.2016 22:05
» » #version 3.5....
» Ja, das ist bekannt, bastle auf Bedarf auch damit, falls jemand das von mir
» wünscht.
» Allerdings ist das Schnee von gestern, da niemand mehr damit wirklich
» arbeitet; proprietär.
» Heute ist dies angesagt:
» http://www.cadsoft.de/eagle-pcb-design-software/partner-produkte/
» Damit bist mit anderen, vor Allem mit Print Herstellern kompatibel.
» Ähnlich ist das 3D Spielchen mit Google's-Trimble's Sketchup.
» Dieses gefällt mir besser, als povray und ist viel einfacher zu bedienen.
» Sketchup wird auch von Konstruktionsfirmen (zB bietet auch RS-Components
» mit
» seinen 3D Ansichten Bauteile im Sketchup Datenformat zum Download an)
» verwendet.
» Ist somit so gesehen auch besser, als mit povray.
» http://www.sketchup.com/download
» https://eagleup.wordpress.com/
» Grüße
» Gerald
für mich reicht es allemal, bin ja nicht mehr im arbeitstress , hab also zeit so zu sagen, und es hält einen geistig fit :-D, klar ist das zeugs antik und wird den heutigen anforderungen nicht mehr gerecht werden.ist halt alles ein kommen und gehen, zur letzteren fraktion gehöre ich auch an :-D, meine hochzeit elektronik ist vorbei mit derer ich mal verheiratet war:lol3:
geralds(R)
Homepage E-Mail
Wien, AT,
10.04.2016,
15:19
@ JBE
eagle3d und povray
hi,
» für mich reicht es allemal, bin ja nicht mehr im arbeitstress , hab also
» zeit so zu sagen, und es hält einen geistig fit :-D, klar ist das zeugs
» antik und wird den heutigen anforderungen nicht mehr gerecht werden.ist
» halt alles ein kommen und gehen, zur letzteren fraktion gehöre ich auch an
» :-D, meine hochzeit elektronik ist vorbei mit derer ich mal verheiratet
» war:lol3:
wegwerfen würde ich povray nicht, weil, man kann auch anderwertig feines basteln.
Und, man kann source dazu schreiben, für seine Zwecke anpassen. hat in seinem Bereich auch einen gewissen Vorteil.
Hast du schon das mit Sketchup probiert?
Wenn nicht, dann probiere diese. damit bist fein
unterwegs mit tollen realistisch aussehenden Bildern.
Die Umsetzung, den Workaround, hatte ich hier im ELKO ja bereits einige Male beschrieben.
Dass geht ruckzuck binnen wenigen Minuten kann dies erledigen.
Ich habe mittlerweile eine Bauteil Biblio erstellt,
in der auch die Widerstände ihre Realwert-Ringe zeigen.
Ist eine Heiden-Arbeit, aber es lohnt sich.
Das Gleiche ist mit den Kondis, Steckern, Halbleiter, zum Teil habe ich auch schon mechanisches in der Biblio.
Tja, Aufträge brauche ich nun, im dies nun auch für andere nutzbar machen
zu können; finde dann einen Ansporn weiter zu machen.
Dann sehe ich einen Mehrwert, außer nur zu spielen.
Gerne kann ich dir helfen, falls Fragen auftauchen.
Die Tools kann man, sollte man ja entsprechend anpassen,
damit sie zB. automatischer arbeiten.
JBE
10.04.2016,
18:35
@ geralds
eagle3d und povray
» hi,
» » für mich reicht es allemal, bin ja nicht mehr im arbeitstress , hab also
» » zeit so zu sagen, und es hält einen geistig fit :-D, klar ist das zeugs
» » antik und wird den heutigen anforderungen nicht mehr gerecht werden.ist
» » halt alles ein kommen und gehen, zur letzteren fraktion gehöre ich auch
» an
» » :-D, meine hochzeit elektronik ist vorbei mit derer ich mal verheiratet
» » war:lol3:
» wegwerfen würde ich povray nicht, weil, man kann auch anderwertig feines
» basteln.
» Und, man kann source dazu schreiben, für seine Zwecke anpassen. hat in
» seinem Bereich auch einen gewissen Vorteil.
» Hast du schon das mit Sketchup probiert?
» Wenn nicht, dann probiere diese. damit bist fein
» unterwegs mit tollen realistisch aussehenden Bildern.
» Die Umsetzung, den Workaround, hatte ich hier im ELKO ja bereits einige
» Male beschrieben.
» Dass geht ruckzuck binnen wenigen Minuten kann dies erledigen.
» Ich habe mittlerweile eine Bauteil Biblio erstellt,
» in der auch die Widerstände ihre Realwert-Ringe zeigen.
» Ist eine Heiden-Arbeit, aber es lohnt sich.
» Das Gleiche ist mit den Kondis, Steckern, Halbleiter, zum Teil habe ich
» auch schon mechanisches in der Biblio.
» Tja, Aufträge brauche ich nun, im dies nun auch für andere nutzbar machen
» zu können; finde dann einen Ansporn weiter zu machen.
» Dann sehe ich einen Mehrwert, außer nur zu spielen.
» Gerne kann ich dir helfen, falls Fragen auftauchen.
» Die Tools kann man, sollte man ja entsprechend anpassen,
» damit sie zB. automatischer arbeiten.
» Grüße
» Gerald
habs mal probiert mit sketchup , die erzeugte eup datei lässt sich importieren , sketchup zeigt nichts an , nun, hab auch ehrlich gesagt kein bock heraus zu finden an was es liegt, dieses gefrickel bis es mal läuft mag ich nicht.
möglich das es eine kleinigkeit ist, sie zu suchen ist nicht so wichtig.
ich nehme den modeler moray, damit kann man auch bauteile generieren, für meine zwecke reicht der, wie gehabt ich bin draussen aus der elektronik, und muss für niemanden etwas entwickeln, somit ist das ganze für mich nicht essentiell, danke dir erst mal, für deine hilfsbereitschaft, vllt irgend wann komme ich auf dich zurück.
