sip-realm (Netzwerktechnik)
ยป Was ibedeutet die angabe sip-realm bei voip?
Ggf. bringt dich das weiter "RFC2617"
siehe > http://rfc.net/rfc2617.html,
Authentifizierung wird detailliert erklaert:
Realm is a opaque string that the user agent should present to the user so he can decide what username and password to use. Usually this is domain of the host the server is running on.
If an empty string "" is used then the server will generate it from the request. In case of REGISTER requests To header field domain will be used (because this header field represents a user being registered), for all other messages From header field domain will be used.
realm:
A string to be displayed to users so they know which username and password to use. This string should contain at least the name of the host performing the authentication and might additionally indicate the collection of users who might have access. An example might be "registered_users@gotham.news.com".
