TCP- und UDP-Ports (Übersicht)
TCP- und UDP-Ports sind eine Software-Abstraktion, um parallele Kommunikationsverbindungen einer oder mehreren Anwendungen voneinander unterscheiden zu können.
Übersicht
Alle Angaben ohne Gewähr!
| Port | Dienst | Beschreibung |
| 1 | tcpmux | TCP Port Service Multiplexer |
| 2 | compressnet | Management Utility |
| 3 | compressnet | Compression Process |
| 5 | rje | Remote Job Entry |
| 7 | echo | Echo |
| 9 | discard | Discard |
| 11 | systat | Active Users |
| 13 | daytime | Daytime |
| 17 | qotd | Quote of the Day |
| 18 | msp | Message Send Protocol |
| 19 | chargen | Character Generator |
| 20 | ftp-data | File Transfer Protocol (Default Data) |
| 21 | ftp | File Transfer Protocol (Control) |
| 22 | ssh | SSH Remote Login Protocol |
| 23 | telnet | Telnet |
| 24 | unbekannter Dienst | any private mail system |
| 25 | smtp | Simple Mail Transfer |
| 27 | nsw-fe | NSW User System FE |
| 29 | msg-icp | MSG ICP |
| 31 | msg-auth | MSG Authentication |
| 33 | dsp | Display Support Protocol |
| 35 | unbekannter Dienst | any private printer server |
| 37 | time | Time |
| 38 | rap | Route Access Protocol |
| 39 | rlp | Resource Location Protocol |
| 41 | graphics | Graphics |
| 42 | nameserver | WINS Host Name Server |
| 43 | nicname | Who Is |
| 44 | mpm-flags | MPM FLAGS Protocol |
| 45 | mpm | Message Processing Module (recv) |
| 46 | mpm-snd | MPM (default send) |
| 47 | ni-ftp | NI FTP |
| 48 | auditd | Digital Audit Daemon |
| 49 | tacacs | Login Host Protocol (TACACS) |
| 50 | re-mail-ck | Remote Mail Checking Protocol |
| 51 | la-maint | IMP Logical Address Maintenance |
| 52 | xns-time | XNS Time Protocol |
| 53 | dns | Domain Name Server |
| 54 | xns-ch | XNS Clearinghouse |
| 55 | isi-gl | ISI Graphics Language |
| 56 | xns-auth | XNS Authentication |
| 57 | unbekannter Dienst | any private terminal access |
| 58 | xns-mail | XNS Mail |
| 59 | unbekannter Dienst | any private file service |
| 60 | unbekannter Dienst | Unassigned |
| 61 | ni-mail | NI MAIL |
| 62 | acas | ACA Services |
| 63 | whois | whois |
| 64 | covia | Communications Integrator (CI) |
| 65 | tacacs-ds | TACACS-Database Service |
| 66 | sql*net | Oracle SQL*NET |
| 67 | bootps | Bootstrap Protocol Server |
| 68 | bootpc | Bootstrap Protocol Client |
| 69 | tftp | Trivial File Transfer |
| 70 | gopher | Gopher |
| 71 | netrjs-1 | Remote Job Service |
| 72 | netrjs-2 | Remote Job Service |
| 73 | netrjs-3 | Remote Job Service |
| 74 | netrjs-4 | Remote Job Service |
| 75 | unbekannter Dienst | any private dial out service |
| 76 | deos | Distributed External Object Store |
| 77 | unbekannter Dienst | any private RJE service |
| 78 | vettcp | vettcp |
| 79 | finger | Finger |
| 80 | http | World Wide Web HTTP |
| 81 | hosts2-ns | HOSTS2 Name Server |
| 82 | xfer | XFER Utility |
| 83 | mit-ml-dev | MIT ML Device |
| 84 | ctf | Common Trace Facility |
| 85 | mit-ml-dev | MIT ML Device |
| 86 | mfcobol | Micro Focus Cobol |
| 87 | unbekannter Dienst | any private terminal link |
| 88 | kerberos | Kerberos |
| 89 | su-mit-tg | SU/MIT Telnet Gateway |
| 90 | dnsix | DNSIX Securit Attribute Token Map |
| 91 | mit-dov | MIT Dover Spooler |
| 92 | npp | Network Printing Protocol |
| 93 | dcp | Device Control Protocol |
| 94 | objcall | Tivoli Object Dispatcher |
| 95 | supdup | SUPDUP |
| 96 | dixie | DIXIE Protocol Specification |
| 97 | swift-rvf | Swift Remote Virtural File Protocol |
| 98 | tacnews | TAC News |
| 99 | metagram | Metagram Relay |
| 100 | newacct | (unauthorized use) |
| 101 | hostname | NIC Host Name Server |
| 102 | iso-tsap | ISO-TSAP Class 0 |
| 103 | gppitnp | Genesis Point-to-Point Trans Net |
| 104 | acr-nema | ACR-NEMA Digital Imag. & Comm. 300 |
| 105 | cso | CCSO name server protocol |
| 106 | 3com-tsmux | 3COM-TSMUX |
| 107 | rtelnet | Remote Telnet Service |
| 108 | snagas | SNA Gateway Access Server |
| 109 | pop2 | Post Office Protocol - Version 2 |
| 110 | pop3 | Post Office Protocol - Version 3 |
| 111 | sunrpc | SUN Remote Procedure Call |
| 112 | mcidas | McIDAS Data Transmission Protocol |
| 113 | auth | Authentication Service |
| 114 | audionews | Audio News Multicast |
| 115 | sftp | Simple File Transfer Protocol |
| 116 | ansanotify | ANSA REX Notify |
| 117 | uucp-path | UUCP Path Service |
| 118 | sqlserv | SQL Services |
| 119 | nntp | Network News Transfer Protocol |
| 120 | cfdptkt | CFDPTKT |
| 121 | erpc | Encore Expedited Remote Pro.Call |
| 122 | smakynet | SMAKYNET |
| 123 | ntp | Network Time Protocol |
| 124 | ansatrader | ANSA REX Trader |
| 125 | locus-map | Locus PC-Interface Net Map Ser |
| 126 | unitary | Unisys Unitary Login |
| 127 | locus-con | Locus PC-Interface Conn Server |
| 128 | gss-xlicen | GSS X License Verification |
| 129 | pwdgen | Password Generator Protocol |
| 130 | cisco-fna | cisco FNATIVE |
| 131 | cisco-tna | cisco TNATIVE |
| 132 | cisco-sys | cisco SYSMAINT |
| 133 | statsrv | Statistics Service |
| 134 | ingres-net | INGRES-NET Service |
| 135 | epmap | DCE endpoint resolution |
| 136 | profile | PROFILE Naming System |
| 137 | netbios-ns | NETBIOS Name Service |
| 138 | netbios-dgm | NETBIOS Datagram Service |
| 139 | netbios-ssn | NETBIOS Session Service |
| 140 | emfis-data | EMFIS Data Service |
| 141 | emfis-cntl | EMFIS Control Service |
| 142 | bl-idm | Britton-Lee IDM |
| 143 | imap | Internet Message Access Protocol |
| 144 | news | NewS |
| 145 | uaac | UAAC Protocol |
| 146 | iso-tp0 | ISO-IP0 |
| 147 | iso-ip | ISO-IP |
| 148 | jargon | Jargon |
| 149 | aed-512 | AED 512 Emulation Service |
| 150 | sql-net | SQL-NET |
| 151 | hems | HEMS |
| 152 | bftp | Background File Transfer Program |
| 153 | sgmp | SGMP |
| 154 | netsc-prod | NETSC |
| 155 | netsc-dev | NETSC |
| 156 | sqlsrv | SQL Service |
| 157 | knet-cmp | KNET/VM Command/Message Protocol |
| 158 | pcmail-srv | PCMail Server |
| 159 | nss-routing | NSS-Routing |
| 160 | sgmp-traps | SGMP-TRAPS |
| 161 | snmp | SNMP |
| 162 | snmptrap | SNMPTRAP |
| 163 | cmip-man | CMIP Manager |
| 164 | cmip-agent | CMIP Agent |
| 165 | xns-courier | Xerox |
| 166 | s-net | Sirius Systems |
| 167 | namp | NAMP |
| 168 | rsvd | RSVD |
| 169 | send | SEND |
| 170 | print-srv | Network PostScript |
| 171 | multiplex | Network Innovations Multiplex |
| 172 | cl/1 | Network Innovations CL/1 |
| 173 | xyplex-mux | Xyplex |
| 174 | mailq | MAILQ |
| 175 | vmnet | VMNET |
| 176 | genrad-mux | GENRAD-MUX |
| 177 | xdmcp | X Display Manager Control Protocol |
| 178 | nextstep | NextStep Window Server |
| 179 | bgp | Border Gateway Protocol |
| 180 | ris | Intergraph |
| 181 | unify | Unify |
| 182 | audit | Unisys Audit SITP |
| 183 | ocbinder | OCBinder |
| 184 | ocserver | OCServer |
| 185 | remote-kis | Remote-KIS |
| 186 | kis | KIS Protocol |
| 187 | aci | Application Communication Interface |
| 188 | mumps | Plus Five's MUMPS |
| 189 | qft | Queued File Transport |
| 190 | gacp | Gateway Access Control Protocol |
| 191 | prospero | Prospero Directory Service |
| 192 | osu-nms | OSU Network Monitoring System |
| 193 | srmp | Spider Remote Monitoring Protocol |
| 194 | irc | Internet Relay Chat Protocol |
| 195 | dn6-nlm-aud | DNSIX Network Level Module Audit |
| 196 | dn6-smm-red | DNSIX Session Mgt Module Audit Redir |
| 197 | dls | Directory Location Service |
| 198 | dls-mon | Directory Location Service Monitor |
| 199 | smux | SMUX |
| 200 | src | IBM System Resource Controller |
| 201 | at-rtmp | AppleTalk Routing Maintenance |
| 202 | at-nbp | AppleTalk Name Binding |
| 203 | at-3 | AppleTalk Unused |
| 204 | at-echo | AppleTalk Echo |
| 205 | at-5 | AppleTalk Unused |
| 206 | at-zis | AppleTalk Zone Information |
| 207 | at-7 | AppleTalk Unused |
| 208 | at-8 | AppleTalk Unused |
| 209 | qmtp | The Quick Mail Transfer Protocol |
| 210 | z39.50 | ANSI Z39.50 |
| 211 | 914c/g | Texas Instruments 914C/G Terminal |
| 212 | anet | ATEXSSTR |
| 213 | ipx | IPX |
| 214 | vmpwscs | VM PWSCS |
| 215 | softpc | Insignia Solutions |
| 216 | CAIlic | Computer Associates Int'l License Server |
| 217 | dbase | dBASE Unix |
| 218 | mpp | Netix Message Posting Protocol |
| 219 | uarps | Unisys ARPs |
| 220 | imap3 | Interactive Mail Access Protocol v3 |
| 221 | fln-spx | Berkeley rlogind with SPX auth |
| 222 | rsh-spx | Berkeley rshd with SPX auth |
| 223 | cdc | Certificate Distribution Center |
| 242 | direct | Direct |
| 243 | sur-meas | Survey Measurement |
| 244 | dayna | Dayna |
| 245 | link | LINK |
| 246 | dsp3270 | Display Systems Protocol |
| 256 | rap | RAP |
| 257 | set | Secure Electronic Transaction |
| 258 | yak-chat | Yak Winsock Personal Chat |
| 259 | esro-gen | Efficient Short Remote Operations |
| 260 | openport | Openport |
| 261 | naming-iiop-ssl | IIOP Naming Service (SSL) |
| 262 | arcisdms | Arcisdms |
| 263 | hdap | HDAP |
| 280 | http-mgmt | http-mgmt |
| 281 | personal-link | Personal Link |
| 282 | cableport-ax | Cable Port A/X |
| 309 | entrusttime | EntrustTime |
| 344 | pdap | Prospero Data Access Protocol |
| 345 | pawserv | Perf Analysis Workbench |
| 346 | zserv | Zebra server |
| 347 | fatserv | Fatmen Server |
| 348 | csi-sgwp | Cabletron Management Protocol |
| 349 | mftp | mftp |
| 350 | matip-type-a | MATIP Type A |
| 351 | matip-type-b | MATIP Type B |
| 371 | clearcase | Clearcase |
| 372 | ulistproc | ListProcessor |
| 373 | legent-1 | Legent Corporation |
| 374 | legent-2 | Legent Corporation |
| 375 | hassle | Hassle |
| 376 | nip | Amiga Envoy Network Inquiry Proto |
| 377 | tnETOS | NEC Corporation |
| 378 | dsETOS | NEC Corporation |
| 379 | is99c | TIA/EIA/IS-99 modem client |
| 380 | is99s | TIA/EIA/IS-99 modem server |
| 381 | hp-collector | hp performance data collector |
| 382 | hp-managed-node | hp performance data managed node |
| 383 | hp-alarm-mgr | hp performance data alarm manager |
| 384 | arns | A Remote Network Server System |
| 385 | ibm-app | IBM Application |
| 386 | asa | ASA Message Router Object Def. |
| 387 | aurp | Appletalk Update-Based Routing Pro |
| 388 | unidata-ldm | Unidata LDM Version 4 |
| 389 | ldap | Lightweight Directory Access Protocol |
| 390 | uis | UIS |
| 391 | synotics-relay | SynOptics SNMP Relay Port |
| 392 | synotics-broker | SynOptics Port Broker Port |
| 393 | dis | Data Interpretation System |
| 394 | embl-ndt | EMBL Nucleic Data Transfer |
| 395 | netcp | NETscout Control Protocol |
| 396 | netware-ip | Novell Netware over IP |
| 397 | mptn | Multi Protocol Trans. Net. |
| 398 | kryptolan | Kryptolan |
| 399 | iso-tsap-c2 | ISO Transport Class 2 Non-Control over TCP |
| 400 | work-sol | Workstation Solutions |
| 401 | ups | Uninterruptible Power Supply |
| 402 | genie | Genie Protocol |
| 403 | decap | decap |
| 404 | nced | nced |
| 405 | ncld | ncld |
| 406 | imsp | Interactive Mail Support Protocol |
| 407 | timbuktu | Timbuktu |
| 408 | prm-sm | Prospero Resource Manager Sys. Man. |
| 409 | prm-nm | Prospero Resource Manager Node Man. |
| 410 | decladebug | DECLadebug Remote Debug Protocol |
| 411 | rmt | Remote MT Protocol |
| 412 | synoptics-trap | Trap Convention Port |
| 413 | smsp | SMSP |
| 414 | infoseek | InfoSeek |
| 415 | bnet | BNet |
| 416 | silverplatter | Silverplatter |
| 417 | onmux | Onmux |
| 418 | hyper-g | Hyper-G |
| 419 | ariel1 | Ariel |
| 420 | smpte | SMPTE |
| 421 | ariel2 | Ariel |
| 422 | ariel3 | Ariel |
| 423 | opc-job-start | IBM Operations Planning and Control Start |
| 424 | opc-job-track | IBM Operations Planning and Control Track |
| 425 | icad-el | ICAD |
| 426 | smartsdp | smartsdp |
| 427 | svrloc | Server Location |
| 428 | ocs_cmu | OCS_CMU |
| 429 | ocs_amu | OCS_AMU |
| 430 | utmpsd | UTMPSD |
| 431 | utmpcd | UTMPCD |
| 432 | iasd | IASD |
| 433 | nnsp | NNSP |
| 434 | mobileip-agent | MobileIP-Agent |
| 435 | mobilip-mn | MobilIP-MN |
| 436 | dna-cml | DNA-CML |
| 437 | comscm | comscm |
| 438 | dsfgw | dsfgw |
| 439 | dasp | dasp |
| 440 | sgcp | sgcp |
| 441 | decvms-sysmgt | decvms-sysmgt |
| 442 | cvc_hostd | cvc_hostd |
| 443 | https | https MCom |
| 444 | snpp | Simple Network Paging Protocol |
| 445 | microsoft-ds | Microsoft-DS |
| 446 | ddm-rdb | DDM-RDB |
| 447 | ddm-dfm | DDM-RFM |
| 448 | ddm-byte | DDM-BYTE |
| 449 | as-servermap | AS Server Mapper |
| 450 | tserver | TServer |
| 451 | sfs-smp-net | Cray Network Semaphore server |
| 452 | sfs-config | Cray SFS config server |
| 453 | creativeserver | CreativeServer |
| 454 | contentserver | ContentServer |
| 455 | creativepartnr | CreativePartnr |
| 456 | macon-tcp | macon-tcp |
| 457 | scohelp | scohelp |
| 458 | appleqtc | apple quick time |
| 459 | ampr-rcmd | ampr-rcmd |
| 460 | skronk | skronk |
| 461 | datasurfsrv | DataRampSrv |
| 462 | datasurfsrvsec | DataRampSrvSec |
| 463 | alpes | alpes |
| 464 | kpasswd | kpasswd |
| 465 | ssmtp | ssmtp |
| 466 | digital-vrc | digital-vrc |
| 467 | mylex-mapd | mylex-mapd |
| 468 | photuris | proturis |
| 469 | rcp | Radio Control Protocol |
| 470 | scx-proxy | scx-proxy |
| 471 | mondex | Mondex |
| 472 | ljk-login | ljk-login |
| 473 | hybrid-pop | hybrid-pop |
| 474 | tn-tl-w1 | tn-tl-w1 |
| 475 | tcpnethaspsrv | tcpnethaspsrv |
| 476 | tn-tl-fd1 | tn-tl-fd1 |
| 477 | ss7ns | ss7ns |
| 478 | spsc | spsc |
| 479 | iafserver | iafserver |
| 480 | iafdbase | iafdbase |
| 481 | ph | Ph service |
| 482 | bgs-nsi | bgs-nsi |
| 483 | ulpnet | ulpnet |
| 484 | integra-sme | Integra Software Management Environment |
| 485 | powerburst | Air Soft Power Burst |
| 486 | avian | avian |
| 487 | saft | saft |
| 488 | gss-http | gss-http |
| 489 | nest-protocol | nest-protocol |
| 490 | micom-pfs | micom-pfs |
| 491 | go-login | go-login |
| 492 | ticf-1 | Transport Independent Convergence for FNA |
| 493 | ticf-2 | Transport Independent Convergence for FNA |
| 494 | pov-ray | POV-Ray |
| 495 | intecourier | intecourier |
| 496 | pim-rp-disc | PIM-RP-DISC |
| 497 | dantz | dantz |
| 498 | siam | siam |
| 499 | iso-ill | ISO ILL Protocol |
| 500 | isakmp | isakmp |
| 501 | stmf | STMF |
| 502 | asa-appl-proto | asa-appl-proto |
| 503 | intrinsa | Intrinsa |
| 504 | citadel | citadel |
| 505 | mailbox-lm | mailbox-lm |
| 506 | ohimsrv | ohimsrv |
| 507 | crs | crs |
| 508 | xvttp | xvttp |
| 509 | snare | snare |
| 510 | fcp | FirstClass Protocol |
| 511 | mynet | mynet-as |
| 512 | exec | remote process execution |
| 513 | login | remote login a la telnet |
| 514 | shell | cmd |
| 515 | printer | spooler |
| 516 | videotex | videotex |
| 517 | talk | like tenex link |
| 518 | ntalk | keine Beschreibung vorhanden |
| 519 | utime | unixtime |
| 520 | efs | extended file name server |
| 521 | ripng | ripng |
| 522 | ulp | ULP |
| 523 | ibm-db2 | IBM-DB2 |
| 524 | ncp | NCP |
| 525 | timed | timeserver |
| 526 | tempo | newdate |
| 527 | stx | Stock IXChange |
| 528 | custix | Customer IXChange |
| 529 | irc-serv | IRC-SERV |
| 530 | courier | rpc |
| 531 | conference | chat |
| 532 | netnews | readnews |
| 533 | netwall | for emergency broadcasts |
| 534 | mm-admin | MegaMedia Admin |
| 535 | iiop | iiop |
| 536 | opalis-rdv | opalis-rdv |
| 537 | nmsp | Networked Media Streaming Protocol |
| 538 | gdomap | gdomap |
| 539 | apertus-ldp | Apertus Technologies Load Determination |
| 540 | uucp | uucpd |
| 541 | uucp-rlogin | uucp-rlogin |
| 542 | commerce | commerce |
| 543 | klogin | keine Beschreibung vorhanden |
| 544 | kshell | krcmd |
| 545 | appleqtcsrvr | appleqtcsrvr |
| 546 | dhcpv6-client | DHCPv6 Client |
| 547 | dhcpv6-server | DHCPv6 Server |
| 548 | afpovertcp | AFP over TCP |
| 549 | idfp | IDFP |
| 550 | new-rwho | new-who |
| 551 | cybercash | cybercash |
| 552 | deviceshare | deviceshare |
| 553 | pirp | pirp |
| 554 | rtsp | Real Time Stream Control Protocol |
| 555 | dsf | keine Beschreibung vorhanden |
| 556 | remotefs | rfs server |
| 557 | openvms-sysipc | openvms-sysipc |
| 558 | sdnskmp | SDNSKMP |
| 559 | teedtap | TEEDTAP |
| 560 | rmonitor | rmonitord |
| 561 | monitor | keine Beschreibung vorhanden |
| 562 | chshell | chcmd |
| 563 | snews | snews |
| 564 | 9pfs | plan 9 file service |
| 565 | whoami | whoami |
| 566 | streettalk | streettalk |
| 567 | banyan-rpc | banyan-rpc |
| 568 | ms-shuttle | microsoft shuttle |
| 569 | ms-rome | microsoft rome |
| 570 | meter | demon |
| 571 | meter | udemon |
| 572 | sonar | sonar |
| 573 | banyan-vip | banyan-vip |
| 574 | ftp-agent | FTP Software Agent System |
| 575 | vemmi | VEMMI |
| 576 | ipcd | ipcd |
| 577 | vnas | vnas |
| 578 | ipdd | ipdd |
| 579 | decbsrv | decbsrv |
| 580 | sntp-heartbeat | SNTP HEARTBEAT |
| 581 | bdp | Bundle Discovery Protocol |
| 600 | ipcserver | Sun IPC server |
| 606 | urm | Cray Unified Resource Manager |
| 607 | nqs | nqs |
| 608 | nsift-uft | Sender-Initiated/Unsolicited File Transfer |
| 609 | npmp-trap | npmp-trap |
| 610 | npmp-local | npmp-local |
| 611 | npmp-gui | npmp-gui |
| 612 | hmmp-ind | HMMP Indication |
| 613 | hmmp-op | HMMP Operation |
| 614 | sshell | SSLshell |
| 615 | sco-inetmgr | Internet Configuration Manager |
| 616 | sco-sysmgr | SCO System Administration Server |
| 617 | sco-dtmgr | SCO Desktop Administration Server |
| 618 | dei-icda | DEI-ICDA |
| 619 | digital-evm | Digital EVM |
| 620 | sco-websrvrmgr | SCO WebServer Manager |
| 633 | servstat | Service Status update (Sterling Software) |
| 634 | ginad | ginad |
| 635 | rlzdbase | RLZ DBase |
| 636 | ssl-ldap | ssl-ldap |
| 637 | lanserver | lanserver |
| 666 | mdqs | keine Beschreibung vorhanden |
| 667 | disclose | campaign contribution disclosures - SDR Technologies |
| 668 | mecomm | MeComm |
| 669 | meregister | MeRegister |
| 670 | vacdsm-sws | VACDSM-SWS |
| 671 | vacdsm-app | VACDSM-APP |
| 672 | vpps-qua | VPPS-QUA |
| 673 | cimplex | CIMPLEX |
| 674 | acap | ACAP |
| 704 | elcsd | errlog copy/server daemon |
| 705 | agentx | AgentX |
| 709 | entrust-kmsh | Entrust Key Management Service Handler |
| 710 | entrust-ash | Entrust Administration Service Handler |
| 729 | netviewdm1 | IBM NetView DM/6000 Server/Client |
| 730 | netviewdm2 | IBM NetView DM/6000 send |
| 731 | netviewdm3 | IBM NetView DM/6000 receive |
| 741 | netgw | netGW |
| 742 | netrcs | Network based Rev. Cont. Sys. |
| 744 | flexlm | Flexible License Manager |
| 747 | fujitsu-dev | Fujitsu Device Control |
| 748 | ris-cm | Russell Info Sci Calendar Manager |
| 749 | kerberos-adm | kerberos administration |
| 750 | rfile | keine Beschreibung vorhanden |
| 751 | pump | keine Beschreibung vorhanden |
| 752 | qrh | keine Beschreibung vorhanden |
| 753 | rrh | keine Beschreibung vorhanden |
| 754 | tell | send |
| 758 | nlogin | keine Beschreibung vorhanden |
| 759 | con | keine Beschreibung vorhanden |
| 760 | ns | keine Beschreibung vorhanden |
| 761 | rxe | keine Beschreibung vorhanden |
| 762 | quotad | keine Beschreibung vorhanden |
| 763 | cycleserv | keine Beschreibung vorhanden |
| 764 | omserv | keine Beschreibung vorhanden |
| 765 | webster | keine Beschreibung vorhanden |
| 767 | phonebook | phone |
| 769 | vid | keine Beschreibung vorhanden |
| 770 | cadlock | keine Beschreibung vorhanden |
| 771 | rtip | keine Beschreibung vorhanden |
| 772 | cycleserv2 | keine Beschreibung vorhanden |
| 773 | submit | keine Beschreibung vorhanden |
| 774 | rpasswd | keine Beschreibung vorhanden |
| 775 | entomb | keine Beschreibung vorhanden |
| 776 | wpages | keine Beschreibung vorhanden |
| 780 | wpgs | keine Beschreibung vorhanden |
| 786 | concert | Concert |
| 800 | mdbs_daemon | keine Beschreibung vorhanden |
| 801 | device | keine Beschreibung vorhanden |
| 886 | iclcnet-locate | ICL coNETion locate server |
| 887 | iclcnet_svinfo | ICL coNETion server info |
| 888 | accessbuilder | AccessBuilder |
| 911 | xact-backup | xact-backup |
| 991 | nas | Netnews Administration System |
| 995 | spop3 | SSL based POP3 |
| 996 | vsinet | vsinet |
| 997 | maitrd | keine Beschreibung vorhanden |
| 998 | busboy | keine Beschreibung vorhanden |
| 999 | garcon | keine Beschreibung vorhanden |
| 1000 | cadlock | keine Beschreibung vorhanden |
| 1001 | WEB ex | WEB ex trojan |
| 1023 | unbekannter Dienst | Reserved |
| 1024 | unbekannter Dienst | Reserved |
| 1025 | blackjack | network blackjack |
| 1027 | ICQ | ICQ? |
| 1030 | iad1 | BBN IAD |
| 1031 | iad2 | BBN IAD |
| 1032 | iad3 | BBN IAD |
| 1047 | neod1 | Sun's NEO Object Request Broker |
| 1048 | neod2 | Sun's NEO Object Request Broker |
| 1058 | nim | nim |
| 1059 | nimreg | nimreg |
| 1067 | instl_boots | Installation Bootstrap Proto. Serv. |
| 1068 | instl_bootc | Installation Bootstrap Proto. Cli. |
| 1080 | socks | Socks |
| 1083 | ansoft-lm-1 | Anasoft License Manager |
| 1084 | ansoft-lm-2 | Anasoft License Manager |
| 1089 | SocksServer trojan | SocksServer trojan |
| 1110 | nfsd-status | Cluster status info |
| 1123 | murray | Murray |
| 1155 | nfa | Network File Access |
| 1212 | lupa | lupa |
| 1222 | nerv | SNI R&D network |
| 1248 | hermes | keine Beschreibung vorhanden |
| 1313 | bmc_patroldb | BMC_PATROLDB |
| 1314 | pdps | Photoscript Distributed Printing System |
| 1345 | vpjp | VPJP |
| 1346 | alta-ana-lm | Alta Analytics License Manager |
| 1347 | bbn-mmc | multi media conferencing |
| 1348 | bbn-mmx | multi media conferencing |
| 1349 | sbook | Registration Network Protocol |
| 1350 | editbench | Registration Network Protocol |
| 1351 | equationbuilder | Digital Tool Works (MIT) |
| 1352 | lotusnote | Lotus Note |
| 1353 | relief | Relief Consulting |
| 1354 | rightbrain | RightBrain Software |
| 1355 | intuitive edge | Intuitive Edge |
| 1356 | cuillamartin | CuillaMartin Company |
| 1357 | pegboard | Electronic PegBoard |
| 1358 | connlcli | CONNLCLI |
| 1359 | ftsrv | FTSRV |
| 1360 | mimer | MIMER |
| 1361 | linx | LinX |
| 1362 | timeflies | TimeFlies |
| 1363 | ndm-requester | Network DataMover Requester |
| 1364 | ndm-server | Network DataMover Server |
| 1365 | adapt-sna | Network Software Associates |
| 1366 | netware-csp | Novell NetWare Comm Service Platform |
| 1367 | dcs | DCS |
| 1368 | screencast | ScreenCast |
| 1369 | gv-us | GlobalView to Unix Shell |
| 1370 | us-gv | Unix Shell to GlobalView |
| 1371 | fc-cli | Fujitsu Config Protocol |
| 1372 | fc-ser | Fujitsu Config Protocol |
| 1373 | chromagrafx | Chromagrafx |
| 1374 | molly | EPI Software Systems |
| 1375 | bytex | Bytex |
| 1376 | ibm-pps | IBM Person to Person Software |
| 1377 | cichlid | Cichlid License Manager |
| 1378 | elan | Elan License Manager |
| 1379 | dbreporter | Integrity Solutions |
| 1380 | telesis-licman | Telesis Network License Manager |
| 1381 | apple-licman | Apple Network License Manager |
| 1382 | udt_os | keine Beschreibung vorhanden |
| 1383 | gwha | GW Hannaway Network License Manager |
| 1384 | os-licman | Objective Solutions License Manager |
| 1385 | atex_elmd | Atex Publishing License Manager |
| 1386 | checksum | CheckSum License Manager |
| 1387 | cadsi-lm | Computer Aided Design Software Inc LM |
| 1388 | objective-dbc | Objective Solutions DataBase Cache |
| 1389 | iclpv-dm | Document Manager |
| 1390 | iclpv-sc | Storage Controller |
| 1391 | iclpv-sas | Storage Access Server |
| 1392 | iclpv-pm | Print Manager |
| 1393 | iclpv-nls | Network Log Server |
| 1394 | iclpv-nlc | Network Log Client |
| 1395 | iclpv-wsm | PC Workstation Manager software |
| 1396 | dvl-activemail | DVL Active Mail |
| 1397 | audio-activmail | Audio Active Mail |
| 1398 | video-activmail | Video Active Mail |
| 1399 | cadkey-licman | Cadkey License Manager |
| 1400 | cadkey-tablet | Cadkey Tablet Daemon |
| 1401 | goldleaf-licman | Goldleaf License Manager |
| 1402 | prm-sm-np | Prospero Resource Manager |
| 1403 | prm-nm-np | Prospero Resource Manager |
| 1404 | igi-lm | Infinite Graphics License Manager |
| 1405 | ibm-res | IBM Remote Execution Starter |
| 1406 | netlabs-lm | NetLabs License Manager |
| 1407 | dbsa-lm | DBSA License Manager |
| 1408 | sophia-lm | Sophia License Manager |
| 1409 | here-lm | Here License Manager |
| 1410 | hiq | HiQ License Manager |
| 1411 | af | AudioFile |
| 1412 | innosys | InnoSys |
| 1413 | innosys-acl | Innosys-ACL |
| 1414 | ibm-mqseries | IBM MQSeries |
| 1415 | dbstar | DBStar |
| 1416 | novell-lu6.2 | Novell LU6.2 |
| 1417 | timbuktu-srv1 | Timbuktu Service 1 Port |
| 1418 | timbuktu-srv2 | Timbuktu Service 2 Port |
| 1419 | timbuktu-srv3 | Timbuktu Service 3 Port |
| 1420 | timbuktu-srv4 | Timbuktu Service 4 Port |
| 1421 | gandalf-lm | Gandalf License Manager |
| 1422 | autodesk-lm | Autodesk License Manager |
| 1423 | essbase | Essbase Arbor Software |
| 1424 | hybrid | Hybrid Encryption Protocol |
| 1425 | zion-lm | Zion Software License Manager |
| 1426 | sais | Satellite-data Acquisition System 1 |
| 1427 | mloadd | mloadd monitoring tool |
| 1428 | informatik-lm | Informatik License Manager |
| 1429 | nms | Hypercom NMS |
| 1430 | tpdu | Hypercom TPDU |
| 1431 | rgtp | Reverse Gossip Transport |
| 1432 | blueberry-lm | Blueberry Software License Manager |
| 1433 | ms-sql-s | Microsoft-SQL-Server |
| 1434 | ms-sql-m | Microsoft-SQL-Monitor |
| 1435 | ibm-cics | IBM CICS |
| 1436 | saism | Satellite-data Acquisition System 2 |
| 1437 | tabula | Tabula |
| 1438 | eicon-server | Eicon Security Agent/Server |
| 1439 | eicon-x25 | Eicon X25/SNA Gateway |
| 1440 | eicon-slp | Eicon Service Location Protocol |
| 1441 | cadis-1 | Cadis License Management |
| 1442 | cadis-2 | Cadis License Management |
| 1443 | ies-lm | Integrated Engineering Software |
| 1444 | marcam-lm | Marcam License Management |
| 1445 | proxima-lm | Proxima License Manager |
| 1446 | ora-lm | Optical Research Associates License Manager |
| 1447 | apri-lm | Applied Parallel Research LM |
| 1448 | oc-lm | OpenConnect License Manager |
| 1449 | peport | PEport |
| 1450 | dwf | Tandem Distributed Workbench Facility |
| 1451 | infoman | IBM Information Management |
| 1452 | gtegsc-lm | GTE Government Systems License Man |
| 1453 | genie-lm | Genie License Manager |
| 1454 | interhdl_elmd | interHDL License Manager |
| 1455 | esl-lm | ESL License Manager |
| 1456 | dca | DCA |
| 1457 | valisys-lm | Valisys License Manager |
| 1458 | nrcabq-lm | Nichols Research Corp. |
| 1459 | proshare1 | Proshare Notebook Application |
| 1460 | proshare2 | Proshare Notebook Application |
| 1461 | ibm_wrless_lan | IBM Wireless LAN |
| 1462 | world-lm | World License Manager |
| 1463 | nucleus | Nucleus |
| 1464 | msl_lmd | MSL License Manager |
| 1465 | pipes | Pipes Platform |
| 1466 | oceansoft-lm | Ocean Software License Manager |
| 1467 | csdmbase | CSDMBASE |
| 1468 | csdm | CSDM |
| 1469 | aal-lm | Active Analysis Limited License Manager |
| 1470 | uaiact | Universal Analytics |
| 1471 | csdmbase | csdmbase |
| 1472 | csdm | csdm |
| 1473 | openmath | OpenMath |
| 1474 | telefinder | Telefinder |
| 1475 | taligent-lm | Taligent License Manager |
| 1476 | clvm-cfg | clvm-cfg |
| 1477 | ms-sna-server | ms-sna-server |
| 1478 | ms-sna-base | ms-sna-base |
| 1479 | dberegister | dberegister |
| 1480 | pacerforum | PacerForum |
| 1481 | airs | AIRS |
| 1482 | miteksys-lm | Miteksys License Manager |
| 1483 | afs | AFS License Manager |
| 1484 | confluent | Confluent License Manager |
| 1485 | lansource | LANSource |
| 1486 | nms_topo_serv | nms_topo_serv |
| 1487 | localinfosrvr | LocalInfoSrvr |
| 1488 | docstor | DocStor |
| 1489 | dmdocbroker | dmdocbroker |
| 1490 | insitu-conf | insitu-conf |
| 1491 | anynetgateway | anynetgateway |
| 1492 | stone-design-1 | stone-design-1 |
| 1493 | netmap_lm | netmap_lm |
| 1494 | ica | ica |
| 1495 | cvc | cvc |
| 1496 | liberty-lm | liberty-lm |
| 1497 | rfx-lm | rfx-lm |
| 1498 | watcom-sql | Watcom-SQL |
| 1499 | fhc | Federico Heinz Consultora |
| 1500 | vlsi-lm | VLSI License Manager |
| 1501 | saiscm | Satellite-data Acquisition System 3 |
| 1502 | shivadiscovery | Shiva |
| 1503 | imtc-mcs | Databeam |
| 1504 | evb-elm | EVB Software Engineering License Manager |
| 1505 | funkproxy | Funk Software |
| 1506 | utcd | Universal Time daemon (utcd) |
| 1507 | symplex | symplex |
| 1508 | diagmond | diagmond |
| 1509 | robcad-lm | Robcad |
| 1510 | mvx-lm | Midland Valley Exploration Ltd. Lic. Man. |
| 1511 | 3l-l1 | 3l-l1 |
| 1512 | wins | Microsoft's Windows Internet Name Service |
| 1513 | fujitsu-dtc | Fujitsu Systems Business of America |
| 1514 | fujitsu-dtcns | Fujitsu Systems Business of America |
| 1515 | ifor-protocol | ifor-protocol |
| 1516 | vpad | Virtual Places Audio data |
| 1517 | vpac | Virtual Places Audio control |
| 1518 | vpvd | Virtual Places Video data |
| 1519 | vpvc | Virtual Places Video control |
| 1520 | atm-zip-office | atm zip office |
| 1521 | ncube-lm | nCube License Manager |
| 1522 | ricardo-lm | Ricardo North America License Manager |
| 1523 | cichild-lm | cichild |
| 1524 | ingreslock | ingres |
| 1525 | orasrv | oracle |
| 1526 | pdap-np | Prospero Data Access Prot non-priv |
| 1527 | tlisrv | oracle |
| 1528 | mciautoreg | micautoreg |
| 1529 | coauthor | oracle |
| 1530 | rap-service | rap-service |
| 1531 | rap-listen | rap-listen |
| 1532 | miroconnect | miroconnect |
| 1533 | virtual-places | Virtual Places Software |
| 1534 | micromuse-lm | micromuse-lm |
| 1535 | ampr-info | ampr-info |
| 1536 | ampr-inter | ampr-inter |
| 1537 | sdsc-lm | isi-lm |
| 1538 | 3ds-lm | 3ds-lm |
| 1539 | intellistor-lm | Intellistor License Manager |
| 1540 | rds | rds |
| 1541 | rds2 | rds2 |
| 1542 | gridgen-elmd | gridgen-elmd |
| 1543 | simba-cs | simba-cs |
| 1544 | aspeclmd | aspeclmd |
| 1545 | vistium-share | vistium-share |
| 1546 | abbaccuray | abbaccuray |
| 1547 | laplink | laplink |
| 1548 | axon-lm | Axon License Manager |
| 1549 | shivahose | Shiva Hose |
| 1550 | 3m-image-lm | Image Storage license manager 3M Company |
| 1551 | hecmtl-db | HECMTL-DB |
| 1552 | pciarray | pciarray |
| 1553 | sna-cs | sna-cs |
| 1554 | caci-lm | CACI Products Company License Manager |
| 1555 | livelan | livelan |
| 1556 | ashwin | AshWin CI Tecnologies |
| 1557 | arbortext-lm | ArborText License Manager |
| 1558 | xingmpeg | xingmpeg |
| 1559 | web2host | web2host |
| 1560 | asci-val | asci-val |
| 1561 | facilityview | facilityview |
| 1562 | pconnectmgr | pconnectmgr |
| 1563 | cadabra-lm | Cadabra License Manager |
| 1564 | pay-per-view | Pay-Per-View |
| 1565 | winddlb | WinDD |
| 1566 | corelvideo | CORELVIDEO |
| 1567 | jlicelmd | jlicelmd |
| 1568 | tsspmap | tsspmap |
| 1569 | ets | ets |
| 1570 | orbixd | orbixd |
| 1571 | rdb-dbs-disp | Oracle Remote Data Base |
| 1572 | chip-lm | Chipcom License Manager |
| 1573 | itscomm-ns | itscomm-ns |
| 1574 | mvel-lm | mvel-lm |
| 1575 | oraclenames | oraclenames |
| 1576 | moldflow-lm | moldflow-lm |
| 1577 | hypercube-lm | hypercube-lm |
| 1578 | jacobus-lm | Jacobus License Manager |
| 1579 | ioc-sea-lm | ioc-sea-lm |
| 1580 | tn-tl-r1 | tn-tl-r1 |
| 1581 | vmf-msg-port | vmf-msg-port |
| 1582 | msims | MSIMS |
| 1583 | simbaexpress | simbaexpress |
| 1584 | tn-tl-fd2 | tn-tl-fd2 |
| 1585 | intv | intv |
| 1586 | ibm-abtact | ibm-abtact |
| 1587 | pra_elmd | pra_elmd |
| 1588 | triquest-lm | triquest-lm |
| 1589 | vqp | VQP |
| 1590 | gemini-lm | gemini-lm |
| 1591 | ncpm-pm | ncpm-pm |
| 1592 | commonspace | commonspace |
| 1593 | mainsoft-lm | mainsoft-lm |
| 1594 | sixtrak | sixtrak |
| 1595 | radio | radio |
| 1596 | radio-sm | radio-sm |
| 1597 | orbplus-iiop | orbplus-iiop |
| 1598 | picknfs | picknfs |
| 1599 | simbaservices | simbaservices |
| 1600 | issd | keine Beschreibung vorhanden |
| 1601 | aas | aas |
| 1602 | inspect | inspect |
| 1603 | picodbc | pickodbc |
| 1604 | icabrowser | icabrowser |
| 1605 | slp | Salutation Manager (Salutation Protocol) |
| 1606 | slm-api | Salutation Manager (SLM-API) |
| 1607 | stt | stt |
| 1608 | smart-lm | Smart Corp. License Manager |
| 1609 | isysg-lm | isysg-lm |
| 1610 | taurus-wh | taurus-wh |
| 1611 | ill | Inter Library Loan |
| 1612 | netbill-trans | NetBill Transaction Server |
| 1613 | netbill-keyrep | NetBill Key Repository |
| 1614 | netbill-cred | NetBill Credential Server |
| 1615 | netbill-auth | NetBill Authorization Server |
| 1616 | netbill-prod | NetBill Product Server |
| 1617 | nimrod-agent | Nimrod Inter-Agent Communication |
| 1618 | skytelnet | skytelnet |
| 1619 | xs-openstorage | xs-openstorage |
| 1620 | faxportwinport | faxportwinport |
| 1621 | softdataphone | softdataphone |
| 1622 | ontime | ontime |
| 1623 | jaleosnd | jaleosnd |
| 1624 | udp-sr-port | udp-sr-port |
| 1625 | svs-omagent | svs-omagent |
| 1636 | cncp | CableNet Control Protocol |
| 1637 | cnap | CableNet Admin Protocol |
| 1638 | cnip | CableNet Info Protocol |
| 1639 | cert-initiator | cert-initiator |
| 1640 | cert-responder | cert-responder |
| 1641 | invision | InVision |
| 1642 | isis-am | isis-am |
| 1643 | isis-ambc | isis-ambc |
| 1644 | saiseh | Satellite-data Acquisition System 4 |
| 1645 | datametrics | datametrics |
| 1646 | sa-msg-port | sa-msg-port |
| 1647 | rsap | rsap |
| 1648 | concurrent-lm | concurrent-lm |
| 1649 | inspect | inspect |
| 1650 | nkd | keine Beschreibung vorhanden |
| 1651 | shiva_confsrvr | shiva_confsrvr |
| 1652 | xnmp | xnmp |
| 1653 | alphatech-lm | alphatech-lm |
| 1654 | stargatealerts | stargatealerts |
| 1655 | dec-mbadmin | dec-mbadmin |
| 1656 | dec-mbadmin-h | dec-mbadmin-h |
| 1657 | fujitsu-mmpdc | fujitsu-mmpdc |
| 1658 | sixnetudr | sixnetudr |
| 1659 | sg-lm | Silicon Grail License Manager |
| 1660 | skip-mc-gikreq | skip-mc-gikreq |
| 1661 | netview-aix-1 | netview-aix-1 |
| 1662 | netview-aix-2 | netview-aix-2 |
| 1663 | netview-aix-3 | netview-aix-3 |
| 1664 | netview-aix-4 | netview-aix-4 |
| 1665 | netview-aix-5 | netview-aix-5 |
| 1666 | netview-aix-6 | netview-aix-6 |
| 1667 | netview-aix-7 | netview-aix-7 |
| 1668 | netview-aix-8 | netview-aix-8 |
| 1669 | netview-aix-9 | netview-aix-9 |
| 1670 | netview-aix-10 | netview-aix-10 |
| 1671 | netview-aix-11 | netview-aix-11 |
| 1672 | netview-aix-12 | netview-aix-12 |
| 1673 | proshare-mc-1 | Intel Proshare Multicast |
| 1674 | proshare-mc-2 | Intel Proshare Multicast |
| 1675 | pdp | Pacific Data Products |
| 1676 | netcomm1 | netcomm1 |
| 1677 | groupwise | groupwise |
| 1678 | prolink | prolink |
| 1679 | darcorp-lm | darcorp-lm |
| 1680 | microcom-sbp | microcom-sbp |
| 1681 | sd-elmd | sd-elmd |
| 1682 | lanyon-lantern | lanyon-lantern |
| 1683 | ncpm-hip | ncpm-hip |
| 1684 | snaresecure | SnareSecure |
| 1685 | n2nremote | n2nremote |
| 1686 | cvmon | cvmon |
| 1687 | nsjtp-ctrl | nsjtp-ctrl |
| 1688 | nsjtp-data | nsjtp-data |
| 1689 | firefox | firefox |
| 1690 | ng-umds | ng-umds |
| 1691 | empire-empuma | empire-empuma |
| 1692 | sstsys-lm | sstsys-lm |
| 1693 | rrirtr | rrirtr |
| 1694 | rrimwm | rrimwm |
| 1695 | rrilwm | rrilwm |
| 1696 | rrifmm | rrifmm |
| 1697 | rrisat | rrisat |
| 1698 | rsvp-encap-1 | RSVP-ENCAPSULATION-1 |
| 1699 | rsvp-encap-2 | RSVP-ENCAPSULATION-2 |
| 1700 | mps-raft | mps-raft |
| 1701 | l2f | l2f |
| 1702 | deskshare | deskshare |
| 1703 | hb-engine | hb-engine |
| 1704 | bcs-broker | bcs-broker |
| 1705 | slingshot | slingshot |
| 1706 | jetform | jetform |
| 1707 | vdmplay | vdmplay |
| 1708 | gat-lmd | gat-lmd |
| 1709 | centra | centra |
| 1710 | impera | impera |
| 1711 | pptconference | pptconference |
| 1712 | registrar | resource monitoring service |
| 1713 | conferencetalk | ConferenceTalk |
| 1714 | sesi-lm | sesi-lm |
| 1715 | houdini-lm | houdini-lm |
| 1716 | xmsg | xmsg |
| 1717 | fj-hdnet | fj-hdnet |
| 1718 | h323gatedisc | h323gatedisc |
| 1719 | h323gatestat | h323gatestat |
| 1720 | h323hostcall | h323hostcall |
| 1721 | caicci | caicci |
| 1722 | hks-lm | HKS License Manager |
| 1723 | pptp | pptp |
| 1724 | csbphonemaster | csbphonemaster |
| 1725 | iden-ralp | iden-ralp |
| 1726 | iberiagames | IBERIAGAMES |
| 1727 | winddx | winddx |
| 1728 | telindus | TELINDUS |
| 1729 | citynl | CityNL License Management |
| 1730 | roketz | roketz |
| 1731 | msiccp | MSICCP |
| 1732 | proxim | proxim |
| 1733 | sipat | sipat |
| 1734 | cambertx-lm | Camber Corporation License Management |
| 1735 | privatechat | PrivateChat |
| 1736 | street-stream | street-stream |
| 1737 | ultimad | ultimad |
| 1738 | gamegen1 | GameGen1 |
| 1739 | webaccess | webaccess |
| 1740 | encore | encore |
| 1741 | cisco-net-mgmt | cisco-net-mgmt |
| 1742 | 3Com-nsd | 3Com-nsd |
| 1743 | cinegrfx-lm | Cinema Graphics License Manager |
| 1744 | ncpm-ft | ncpm-ft |
| 1745 | remote-winsock | remote-winsock |
| 1746 | ftrapid-1 | ftrapid-1 |
| 1747 | ftrapid-2 | ftrapid-2 |
| 1748 | oracle-em1 | oracle-em1 |
| 1749 | aspen-services | aspen-services |
| 1750 | sslp | Simple Socket Library's PortMaster |
| 1751 | swiftnet | SwiftNet |
| 1752 | lofr-lm | Leap of Faith Research License Manager |
| 1753 | translogic-lm | Translogic License Manager |
| 1754 | oracle-em2 | oracle-em2 |
| 1755 | ms-streaming | ms-streaming |
| 1756 | capfast-lmd | capfast-lmd |
| 1757 | cnhrp | cnhrp |
| 1758 | tftp-mcast | tftp-mcast |
| 1759 | spss-lm | SPSS License Manager |
| 1760 | www-ldap-gw | www-ldap-gw |
| 1761 | cft-0 | cft-0 |
| 1762 | cft-1 | cft-1 |
| 1763 | cft-2 | cft-2 |
| 1764 | cft-3 | cft-3 |
| 1765 | cft-4 | cft-4 |
| 1766 | cft-5 | cft-5 |
| 1767 | cft-6 | cft-6 |
| 1768 | cft-7 | cft-7 |
| 1769 | bmc-net-adm | bmc-net-adm |
| 1770 | bmc-net-svc | bmc-net-svc |
| 1771 | vaultbase | vaultbase |
| 1772 | essweb-gw | EssWeb Gateway |
| 1773 | kmscontrol | KMSControl |
| 1774 | global-dtserv | global-dtserv |
| 1776 | femis | Federal Emergency Management Information System |
| 1777 | powerguardian | powerguardian |
| 1778 | prodigy-internet | prodigy-internet |
| 1779 | pharmasoft | pharmasoft |
| 1780 | dpkeyserv | dpkeyserv |
| 1781 | answersoft-lm | answersoft-lm |
| 1782 | hp-hcip | hp-hcip |
| 1783 | fjris | Fujitsu Remote Install Service |
| 1784 | finle-lm | Finle License Manager |
| 1785 | windlm | Wind River Systems License Manager |
| 1786 | funk-logger | funk-logger |
| 1787 | funk-license | funk-license |
| 1788 | psmond | psmond |
| 1789 | hello | hello |
| 1790 | nmsp | Narrative Media Streaming Protocol |
| 1791 | ea1 | EA1 |
| 1792 | ibm-dt-2 | ibm-dt-2 |
| 1793 | rsc-robot | rsc-robot |
| 1794 | cera-bcm | cera-bcm |
| 1795 | dpi-proxy | dpi-proxy |
| 1796 | vocaltec-admin | Vocaltec Server Administration |
| 1797 | uma | UMA |
| 1798 | etp | Event Transfer Protocol |
| 1799 | netrisk | NETRISK |
| 1800 | ansys-lm | ANSYS-License manager |
| 1801 | msmq | Microsoft Message Que |
| 1802 | concomp1 | ConComp1 |
| 1803 | hp-hcip-gwy | HP-HCIP-GWY |
| 1804 | enl | ENL |
| 1805 | enl-name | ENL-Name |
| 1806 | musiconline | Musiconline |
| 1807 | fhsp | Fujitsu Hot Standby Protocol |
| 1808 | oracle-vp2 | Oracle-VP2 |
| 1809 | oracle-vp1 | Oracle-VP1 |
| 1810 | jerand-lm | Jerand License Manager |
| 1811 | scientia-sdb | Scientia-SDB |
| 1812 | radius | RADIUS |
| 1813 | radius-acct | RADIUS Accounting |
| 1814 | tdp-suite | TDP Suite |
| 1815 | mmpft | MMPFT |
| 1818 | etftp | Enhanced Trivial File Transfer Protocol |
| 1819 | plato-lm | Plato License Manager |
| 1820 | mcagent | mcagent |
| 1821 | donnyworld | donnyworld |
| 1822 | es-elmd | es-elmd |
| 1823 | unisys-lm | Unisys Natural Language License Manager |
| 1824 | metrics-pas | metrics-pas |
| 1901 | fjicl-tep-a | Fujitsu ICL Terminal Emulator Program A |
| 1902 | fjicl-tep-b | Fujitsu ICL Terminal Emulator Program B |
| 1903 | linkname | Local Link Name Resolution |
| 1904 | fjicl-tep-c | Fujitsu ICL Terminal Emulator Program C |
| 1905 | sugp | Secure UP.Link Gateway Protocol |
| 1906 | tpmd | TPortMapperReq |
| 1907 | intrastar | IntraSTAR |
| 1908 | dawn | Dawn |
| 1909 | global-wlink | Global World Link |
| 1911 | mtp | Starlight Networks Multimedia Transport Protocol |
| 1912 | unbekannter Dienst | Unassigned |
| 1913 | armadp | armadp |
| 1914 | elm-momentum | Elm-Momentum |
| 1915 | facelink | FACELINK |
| 1916 | persoft | Persoft Persona |
| 1917 | noagent | nOAgent |
| 1918 | can-nds | Candle Directory Service - NDS |
| 1919 | can-dch | Candle Directory Service - DCH |
| 1920 | can-ferret | Candle Directory Service - FERRET |
| 1944 | close-combat | close-combat |
| 1945 | dialogic-elmd | dialogic-elmd |
| 1946 | tekpls | tekpls |
| 1947 | hlserver | hlserver |
| 1948 | eye2eye | eye2eye |
| 1949 | ismaeasdaqlive | ISMA Easdaq Live |
| 1950 | ismaeasdaqtest | ISMA Easdaq Test |
| 1951 | bcs-lmserver | bcs-lmserver |
| 1973 | dlsrap | Data Link Switching Remote Access Protocol |
| 1985 | foliocorp | Folio Remote Server |
| 1986 | licensedaemon | cisco license management |
| 1987 | tr-rsrb-p1 | cisco RSRB Priority 1 port |
| 1988 | tr-rsrb-p2 | cisco RSRB Priority 2 port |
| 1989 | tr-rsrb-p3 | cisco RSRB Priority 3 port |
| 1990 | stun-p1 | cisco STUN Priority 1 port |
| 1991 | stun-p2 | cisco STUN Priority 2 port |
| 1992 | stun-p3 | cisco STUN Priority 3 port |
| 1993 | snmp-tcp-port | cisco SNMP TCP port |
| 1994 | stun-port | cisco serial tunnel port |
| 1995 | perf-port | cisco perf port |
| 1996 | tr-rsrb-port | cisco Remote SRB port |
| 1997 | gdp-port | cisco Gateway Discovery Protocol |
| 1998 | x25-svc-port | cisco X.25 service (XOT) |
| 1999 | tcp-id-port | cisco identification port |
| 2000 | callbook | keine Beschreibung vorhanden |
| 2001 | dc | keine Beschreibung vorhanden |
| 2002 | globe | keine Beschreibung vorhanden |
| 2004 | mailbox | keine Beschreibung vorhanden |
| 2005 | berknet | keine Beschreibung vorhanden |
| 2006 | invokator | keine Beschreibung vorhanden |
| 2007 | dectalk | keine Beschreibung vorhanden |
| 2008 | conf | keine Beschreibung vorhanden |
| 2009 | news | n |
| 2010 | search | keine Beschreibung vorhanden |
| 2011 | raid-cc | raid |
| 2012 | ttyinfo | keine Beschreibung vorhanden |
| 2013 | raid-am | keine Beschreibung vorhanden |
| 2014 | troff | keine Beschreibung vorhanden |
| 2015 | cypress | keine Beschreibung vorhanden |
| 2016 | bootserver | keine Beschreibung vorhanden |
| 2017 | cypress-stat | keine Beschreibung vorhanden |
| 2018 | terminaldb | keine Beschreibung vorhanden |
| 2019 | whosockami | keine Beschreibung vorhanden |
| 2020 | xinupageserver | keine Beschreibung vorhanden |
| 2021 | servexec | keine Beschreibung vorhanden |
| 2022 | down | keine Beschreibung vorhanden |
| 2023 | xinuexpansion3 | keine Beschreibung vorhanden |
| 2024 | xinuexpansion4 | keine Beschreibung vorhanden |
| 2025 | ellpack | keine Beschreibung vorhanden |
| 2026 | scrabble | keine Beschreibung vorhanden |
| 2027 | shadowserver | keine Beschreibung vorhanden |
| 2028 | submitserver | keine Beschreibung vorhanden |
| 2030 | device2 | keine Beschreibung vorhanden |
| 2032 | blackboard | keine Beschreibung vorhanden |
| 2033 | glogger | keine Beschreibung vorhanden |
| 2034 | scoremgr | keine Beschreibung vorhanden |
| 2035 | imsldoc | keine Beschreibung vorhanden |
| 2038 | objectmanager | keine Beschreibung vorhanden |
| 2040 | lam | keine Beschreibung vorhanden |
| 2041 | interbase | keine Beschreibung vorhanden |
| 2042 | isis | isis |
| 2043 | isis-bcast | isis-bcast |
| 2044 | rimsl | keine Beschreibung vorhanden |
| 2045 | cdfunc | keine Beschreibung vorhanden |
| 2046 | sdfunc | keine Beschreibung vorhanden |
| 2047 | dls | keine Beschreibung vorhanden |
| 2048 | dls-monitor | keine Beschreibung vorhanden |
| 2049 | shilp | keine Beschreibung vorhanden |
| 2065 | dlsrpn | Data Link Switch Read Port Number |
| 2067 | dlswpn | Data Link Switch Write Port Number |
| 2102 | zephyr-srv | Zephyr server |
| 2103 | zephyr-clt | Zephyr serv-hm connection |
| 2104 | zephyr-hm | Zephyr hostmanager |
| 2105 | minipay | MiniPay |
| 2201 | ats | Advanced Training System Program |
| 2202 | imtc-map | Int. Multimedia Teleconferencing Cosortium |
| 2213 | kali | Kali |
| 2221 | unreg-ab1 | Allen-Bradley unregistered port |
| 2222 | unreg-ab2 | Allen-Bradley unregistered port |
| 2223 | inreg-ab3 | Allen-Bradley unregistered port |
| 2232 | ivs-video | IVS Video default |
| 2233 | infocrypt | INFOCRYPT |
| 2234 | directplay | DirectPlay |
| 2235 | sercomm-wlink | Sercomm-WLink |
| 2236 | nani | Nani |
| 2237 | optech-port1-lm | Optech Port1 License Manager |
| 2238 | aviva-sna | AVIVA SNA SERVER |
| 2239 | imagequery | Image Query |
| 2241 | ivsd | IVS Daemon |
| 2279 | xmquery | xmquery |
| 2280 | lnvpoller | LNVPOLLER |
| 2281 | lnvconsole | LNVCONSOLE |
| 2282 | lnvalarm | LNVALARM |
| 2283 | lnvstatus | LNVSTATUS |
| 2284 | lnvmaps | LNVMAPS |
| 2285 | lnvmailmon | LNVMAILMON |
| 2286 | nas-metering | NAS-Metering |
| 2287 | dna | DNA |
| 2288 | netml | NETML |
| 2301 | CIM | Compaq Insight Manager |
| 2307 | pehelp | pehelp |
| 2401 | cvspserver | cvspserver |
| 2500 | rtsserv | Resource Tracking system server |
| 2501 | rtsclient | Resource Tracking system client |
| 2564 | hp-3000-telnet | HP 3000 NS/VT block mode telnet |
| 2583 | Wincrash | Wincrash V2.0 trojan |
| 2592 | netrek | netrek |
| 2700 | tqdata | tqdata |
| 2784 | www-dev | world wide web - development |
| 2785 | aic-np | aic-np |
| 2786 | aic-oncrpc | aic-oncrpc - Destiny MCD database |
| 2787 | piccolo | piccolo - Cornerstone Software |
| 2788 | fryeserv | NetWare Loadable Module - Seagate Software |
| 2789 | media-agent | Media Agent |
| 2801 | Phineas | Phineas trojan |
| 2908 | mao | mao |
| 2909 | funk-dialout | Funk Dialout |
| 2910 | tdaccess | TDAccess |
| 2911 | blockade | Blockade |
| 2912 | epicon | Epicon |
| 3000 | hbci | HBCI |
| 3001 | redwood-broker | Redwood Broker |
| 3002 | exlm-agent | EXLM Agent |
| 3010 | gw | Telerate Workstation |
| 3011 | trusted-web | Trusted Web |
| 3047 | hlserver | Fast Security HL Server |
| 3048 | pctrader | Sierra Net PC Trader |
| 3049 | NSWS | keine Beschreibung vorhanden |
| 3128 | squid | Squid Proxy |
| 3141 | vmodem | VMODEM |
| 3142 | rdc-wh-eos | RDC WH EOS |
| 3143 | seaview | Sea View |
| 3144 | tarantella | Tarantella |
| 3145 | csi-lfap | CSI-LFAP |
| 3264 | ccmail | cc:mail/lotus |
| 3333 | dec-notes | DEC Notes |
| 3421 | bmap | Bull Apprise portmapper |
| 3454 | mira | Apple Remote Access Protocol |
| 3455 | prsvp | RSVP Port |
| 3456 | vat | VAT default data |
| 3457 | vat-control | VAT default control |
| 3883 | Deep Throat | Deep Throat 2 trojan |
| 3900 | udt_os | Unidata UDT OS |
| 3984 | mapper-nodemgr | MAPPER network node manager |
| 3985 | mapper-mapethd | MAPPER TCP/IP server |
| 3986 | mapper-ws_ethd | MAPPER workstation server |
| 4008 | netcheque | NetCheque accounting |
| 4009 | chimera-hwm | Chimera HWM |
| 4132 | nuts_dem | NUTS Daemon |
| 4133 | nuts_bootp | NUTS Bootp Server |
| 4134 | nifty-hmi | NIFTY-Serve HMI protocol |
| 4321 | rwhois | Remote Who Is |
| 4343 | unicall | UNICALL |
| 4444 | krb524 | KRB524 |
| 4445 | upnotifyp | UPNOTIFYP |
| 4446 | n1-fwp | N1-FWP |
| 4447 | n1-rmgmt | N1-RMGMT |
| 4448 | asc-slmd | ASC Licence Manager |
| 4449 | arcryptoip | ARCrypto IP |
| 4450 | camp | Camp |
| 4451 | ctisystemmsg | CTI System Msg |
| 4452 | ctiprogramload | CTI Program Load |
| 4453 | nssalertmgr | NSS Alert Manager |
| 4454 | nssagentmgr | NSS Agent Manager |
| 4500 | sae-urn | sae-urn |
| 4501 | urn-x-cdchoice | urn-x-cdchoice |
| 4672 | rfa | remote file access server |
| 5000 | commplex-main | keine Beschreibung vorhanden |
| 5001 | commplex-link | keine Beschreibung vorhanden |
| 5002 | rfe | radio free ethernet |
| 5003 | claris-fmpro | Claris FileMaker Pro |
| 5004 | avt-profile-1 | avt-profile-1 |
| 5005 | avt-profile-2 | avt-profile-2 |
| 5010 | telelpathstart | TelepathStart |
| 5011 | telelpathattack | TelepathAttack |
| 5020 | zenginkyo-1 | zenginkyo-1 |
| 5021 | zenginkyo-2 | zenginkyo-2 |
| 5050 | mmcc | multimedia conference control tool |
| 5145 | rmonitor_secure | keine Beschreibung vorhanden |
| 5150 | atmp | Ascend Tunnel Management Protocol |
| 5190 | aol | America-Online |
| 5191 | aol-1 | AmericaOnline1 |
| 5192 | aol-2 | AmericaOnline2 |
| 5193 | aol-3 | AmericaOnline3 |
| 5236 | padl2sim | keine Beschreibung vorhanden |
| 5300 | hacl-hb | # HA cluster heartbeat |
| 5301 | hacl-gs | # HA cluster general services |
| 5302 | hacl-cfg | # HA cluster configuration |
| 5303 | hacl-probe | # HA cluster probing |
| 5304 | hacl-local | # HA Cluster Commands |
| 5305 | hacl-test | # HA Cluster Test |
| 5400 | excerpt | Excerpt Search |
| 5401 | excerpts | Excerpt Search Secure |
| 5555 | personal-agent | Personal Agent |
| 5631 | pcanywheredata | pcANYWHEREdata |
| 5632 | pcanywherestat | pcANYWHEREstat |
| 5678 | rrac | Remote Replication Agent Connection |
| 5679 | dccm | Direct Cable Connect Manager |
| 5713 | proshareaudio | proshare conf audio |
| 5714 | prosharevideo | proshare conf video |
| 5715 | prosharedata | proshare conf data |
| 5716 | prosharerequest | proshare conf request |
| 5717 | prosharenotify | proshare conf notify |
| 5729 | openmail | Openmail User Agent Layer |
| 5742 | Wincrash | Wincrash V1.03 |
| 5745 | fcopy-server | fcopy-server |
| 5755 | openmailg | OpenMail Desk Gateway server |
| 5757 | x500ms | OpenMail X.500 Directory Server |
| 5766 | openmailns | OpenMail NewMail Server |
| 5767 | s-openmail | OpenMail Suer Agent Layer (Secure) |
| 5800 | VNC | Virtual Network Computing server |
| 5900 | VNC | Virtual Network Computing server |
| 6000 | x11 | -6063 X Window System |
| 6110 | softcm | HP SoftBench CM |
| 6111 | spc | HP SoftBench Sub-Process Control |
| 6112 | dtspcd | dtspcd |
| 6123 | backup-express | Backup Express |
| 6141 | meta-corp | Meta Corporation License Manager |
| 6142 | aspentec-lm | Aspen Technology License Manager |
| 6143 | watershed-lm | Watershed License Manager |
| 6144 | statsci1-lm | StatSci License Manager - 1 |
| 6145 | statsci2-lm | StatSci License Manager - 2 |
| 6146 | lonewolf-lm | Lone Wolf Systems License Manager |
| 6147 | montage-lm | Montage License Manager |
| 6148 | ricardo-lm | Ricardo North America License Manager |
| 6149 | tal-pod | tal-pod |
| 6253 | crip | CRIP |
| 6389 | clariion-evr01 | clariion-evr01 |
| 6455 | skip-cert-recv | SKIP Certificate Receive |
| 6456 | skip-cert-send | SKIP Certificate Send |
| 6558 | xdsxdm | keine Beschreibung vorhanden |
| 6670 | vocaltec-gold | Vocaltec Global Online Directory |
| 6672 | vision_server | vision_server |
| 6673 | vision_elmd | vision_elmd |
| 6831 | ambit-lm | ambit-lm |
| 6969 | acmsoda | acmsoda |
| 7000 | afs3-fileserver | file server itself |
| 7001 | afs3-callback | callbacks to cache managers |
| 7002 | afs3-prserver | users & groups database |
| 7003 | afs3-vlserver | volume location database |
| 7004 | afs3-kaserver | AFS/Kerberos authentication service |
| 7005 | afs3-volser | volume managment server |
| 7006 | afs3-errors | error interpretation service |
| 7007 | afs3-bos | basic overseer process |
| 7008 | afs3-update | server-to-server updater |
| 7009 | afs3-rmtsys | remote cache manager service |
| 7010 | ups-onlinet | onlinet uninterruptable power supplies |
| 7099 | lazy-ptop | lazy-ptop |
| 7100 | font-service | X Font Service |
| 7121 | virprot-lm | Virtual Prototypes License Manager |
| 7174 | clutild | Clutild |
| 7200 | fodms | FODMS FLIP |
| 7201 | dlip | DLIP |
| 7395 | winqedit | winqedit |
| 7491 | telops-lmd | telops-lmd |
| 7511 | pafec-lm | pafec-lm |
| 7777 | cbt | cbt |
| 7781 | accu-lmgr | accu-lmgr |
| 7999 | irdmi2 | iRDMI2 |
| 8000 | irdmi | iRDMI/Shoutcast Server |
| 8010 | wingate-logfile | Wingate web logfile |
| 8032 | pro-ed | ProEd |
| 8080 | WWW-Proxy | Standard HTTP Proxy |
| 8450 | npmp | npmp |
| 8888 | ddi-tcp-1 | NewsEDGE server TCP (TCP 1) |
| 8889 | ddi-tcp-2 | Desktop Data TCP 1 |
| 8890 | ddi-tcp-3 | Desktop Data TCP 2 |
| 8891 | ddi-tcp-4 | Desktop Data TCP 3: NESS application |
| 8892 | ddi-tcp-5 | Desktop Data TCP 4: FARM product |
| 8893 | ddi-tcp-6 | Desktop Data TCP 5: NewsEDGE/Web application |
| 8894 | ddi-tcp-7 | Desktop Data TCP 6: COAL application |
| 9000 | cslistener | CSlistener |
| 9100 | JetDirect | HP JetDirect Printer Server |
| 9535 | man | keine Beschreibung vorhanden |
| 9876 | sd | Session Director |
| 9992 | palace | Palace |
| 9993 | palace | Palace |
| 9994 | palace | Palace |
| 9995 | palace | Palace |
| 9996 | palace | Palace |
| 9997 | palace | Palace |
| 9998 | distinct32 | Distinct32 |
| 9999 | distinct | distinct |
| 10000 | ndmp | Network Data Management Protocol |
| 11000 | SSTROJG | SSTROJG trojan |
| 12345 | Netbus | Win95/NT Netbus backdoor |
| 12753 | tsaf | tsaf port |
| 13223 | PowWow | PowWow chat program |
| 17007 | isode-dua | keine Beschreibung vorhanden |
| 18000 | biimenu | Beckman Instruments |
| 20001 | Millenium | Millenium trojan |
| 20024 | Netbus | Netbus 2.0 Pro |
| 21554 | GirlFriend | GirlFriend trojan |
| 21845 | webphone | webphone |
| 21846 | netspeak-is | NetSpeak Corp. Directory Services |
| 21847 | netspeak-cs | NetSpeak Corp. Connection Services |
| 21848 | netspeak-acd | NetSpeak Corp. Automatic Call Distribution |
| 21849 | netspeak-cps | NetSpeak Corp. Credit Processing System |
| 22273 | wnn6 | wnn6 |
| 22347 | WIBU | WIBU dongle server |
| 22555 | vocaltec-wconf | Vocaltec Web Conference |
| 22800 | aws-brf | Telerate Information Platform LAN |
| 22951 | brf-gw | Telerate Information Platform WAN |
| 23456 | Evil FTP | Evil FTP trojan |
| 25000 | icl-twobase1 | icl-twobase1 |
| 25001 | icl-twobase2 | icl-twobase2 |
| 25002 | icl-twobase3 | icl-twobase3 |
| 25003 | icl-twobase4 | icl-twobase4 |
| 25004 | icl-twobase5 | icl-twobase5 |
| 25005 | icl-twobase6 | icl-twobase6 |
| 25006 | icl-twobase7 | icl-twobase7 |
| 25007 | icl-twobase8 | icl-twobase8 |
| 25008 | icl-twobase9 | icl-twobase9 |
| 25009 | icl-twobase10 | icl-twobase10 |
| 25793 | vocaltec-hos | Vocaltec Address Server |
| 25867 | WebCam32 | WebCam32 Admin |
| 26000 | quake | quake |
| 26208 | wnn6-ds | wnn6-ds |
| 30303 | Sockets De Troie | Sockets De Troie trojan |
| 47557 | dbbrowse | Databeam Corporation |
| 47806 | ap | ALC Protocol |
| 47808 | bacnet | Building Automation and Control Networks |
| 54320 | BO2K | Back Orifice 2000 |
| 65000 | Devil | Devil trojan |
- TCP - Transmission Control Protocol
- UDP - User Datagram Protocol
- TCP- und UDP-Ports
- MPTCP - Multipath Transmission Control Protocol
- TCP/IP
Netzwerktechnik-Fibel
